It is currently Wed Mar 29, 2017 8:10 pm
PostPosted: Tue May 14, 2013 3:48 pm
For SRAM shifters its tough to get the cable through without it catching and unraveling. I've tried soldering it but no luck, whatever is on the cable interferes even with flux. So anyone know what brand of shft cable comes with the end pre soldered? I know I've seen them somewhere.
PostPosted: Tue May 14, 2013 4:02 pm
there are both 1.2mm and 1.1mm gear cables, for sram i think 1.1mm is expected
if the end is neatly cut it should go through, you need to have the lever in the correct position too so that the cable has the easiest path
PostPosted: Tue May 14, 2013 4:08 pm
I agree it should go through but lots of people have the same issue
PostPosted: Tue May 14, 2013 4:56 pm
All new cables I've used have been soldered. I don't have issue getting them through. I used to think I had to take the that plate off but have since figured out how to get them trough without doing so.
New Red shifters are much easier to get cables through.
PostPosted: Tue May 14, 2013 5:51 pm
tbh i've never had a problem (old sram red), but i used to do a *lot* of fine wiring!
rather than soldering, try a *small* drop of superglue on the very tip of the cable - too much will wick up the strands and stop it flexing - it'll be enough to stop strands separating, might be wise to degrease the tip first in case it's lubed
you can scrape any excess glue from the outside with a razor blade, so the diameter should be unchanged, unlike when applying solder
PostPosted: Tue May 14, 2013 9:58 pm
Ditto on the superglue method.
It's very hard to solder stainless cables. Cheap galvanized cables are easy, but I wouldnt use them for other reasons.
I have a feeling some of those "soldered" ends are welded, or at least heated much hotter.
PostPosted: Wed May 15, 2013 2:27 am
They don't solder or weld the ends. In manufacturing they use arc cutting do it fuses the ends when cut to prevent unraveling.
PostPosted: Wed May 15, 2013 5:39 am
I've found that filing the end of the cable so that its smooth and blunt with no sharp points helps with feeding the cables through. Otherwise to answer your question, Jagwire cables have "soldered" ends.
PostPosted: Wed May 15, 2013 5:53 am
I will pile on with the superglue method. The Superglue gel works the best. Just a small drop. Another method I have seen used is JB Weld. The benefit of that is you can sand the JB once it cures if it is too big.
PostPosted: Wed May 15, 2013 5:11 pm
basically every single end cable sold is "soldered".
The best solution for SRAM install is to pre bend the cable end a touch-wrap the end around a 5mm key to give it just a little curve at the tip. Install with the curve going "up and around the spool", goes in easy. Even works with cut cables if the cut was clean, Superglue if needed.
after 2 drinks I'm a loser, after 3 a star
There are no new unread posts for this topic. What is necessary for DI2 Syncro Shift?
djwalker
Tue Dec 20, 2016 9:47 pm
TurboKoo View the latest post
There are no new unread posts for this topic. 34/52T Campagnolo shift quality?
RedRacer
Tue Sep 06, 2016 5:51 am
Kurets View the latest post
There are no new unread posts for this topic. Handlebars designed for shift levers?
BiaNeutron
Mon Jan 09, 2017 2:52 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Electronic front shift question
mbrider
Wed Jun 01, 2016 2:40 am
2lo8 View the latest post
There are no new unread posts for this topic. Current gen SRAM cassette shift quality
morganb
7
469
Sun Mar 19, 2017 8:13 pm
evan326 View the latest post
Users browsing this forum: Baidu [Spider], beanbiken, CrankAddictsRich, Gearhead65, Google [Bot], Google Adsense [Bot], jeffy, Miller, preludervtec, SuperDomestique, TiCass, Yahoo [Bot] and 37 guests
