It is currently Fri Oct 20, 2017 5:49 pm
PostPosted: Sun May 12, 2013 2:49 pm
Hi everyone, so for a while now ive been looking for the flat bearing cover for the systemsix headset. Ive checked just about everywhere, cannondale experts has the supersix top cap but i emailed them and they confirmed it is not the same piece. Does anyone know where i can find just the top cap? Thanks
PostPosted: Sun May 12, 2013 8:25 pm
Do you have a photo of what you're looking for? I have some assorted Sys6 parts laying around.
PostPosted: Sun May 12, 2013 9:06 pm
Thanks for the reply, but as luck would have it i just found the piece! Case closed
PostPosted: Sun May 12, 2013 9:35 pm
This one is part of the standard headset assembly, it's just underneath another one:
PostPosted: Tue May 14, 2013 4:15 pm
That's actually just a very low-stack headset cone spacer. You should be able to use any cone spacer (taller ones look like cones, hence the name) of the same height. Loks like you probably have 7.5mm cone with a 5mm spacer.
PostPosted: Tue May 14, 2013 9:33 pm
Not really...the System Six's head tube is 1.5 all the way through. You cannot use a 1 1/8 bearing cover. The lower cover measures 5mm.
PostPosted: Tue May 14, 2013 9:41 pm
Yeah, I was doing some research on slamming my own stems today and now see that Cannondales use dust covers with lips rather than normal 1.125" cones. There are a few companies that make them aftermarket:
http://metallicpoutine.com/shop/headset ... er-caad10/
http://veloflyte.com/ultra_low_stack_he ... st_shields
Edit: Oops, read SuperSix, not SystemSix. Feel free to ignore me.
You can get a full SystemSix headset for around $75-90, but I don't see lone dustcaps anywhere.
PostPosted: Wed May 15, 2013 9:23 pm
Those will not fit a System Six 1.5 headtube.
The System head tube does not taper.
There are no new unread posts for this topic. Attachment(s) question about spacer/bearing cover on Supersix Evo
garjo
16
1387
Mon Jan 23, 2017 12:26 am
bikerjulio View the latest post
There are no new unread posts for this topic. Attachment(s) SystemSix carbon fork with starnut
martinko
Sun Oct 15, 2017 5:37 pm
martinko View the latest post
There are no new unread posts for this topic. Headset dust cover - BAAAAAAAD
DWatkinsBSB
Wed Jun 14, 2017 3:33 pm
PinaRene View the latest post
There are no new unread posts for this topic. Frame hole (gear cables) cover
itguy
Tue Dec 06, 2016 5:54 pm
mattr View the latest post
There are no new unread posts for this topic. Alternative Tool For Removing Battery Cover
ipenguinking
7
302
Sat Oct 14, 2017 3:20 pm
ipenguinking View the latest post
Users browsing this forum: antonioiglesius, Autriche, mile2424, uraz and 37 guests
