It is currently Thu Feb 23, 2017 8:02 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu May 09, 2013 1:53 pm
In passing, a SRAM tech told me that I'd see better front shifting if I was running a 1091R chain (w/ Yaw & X-Glide rings), rather than the KMC X10SL chain. I thought the front shifting was already really good, but I do wonder if it gets better - or if it was just his way to push more SRAM stuff.
Has anyone run these two chains and can compare the front shifting?
PostPosted: Fri May 10, 2013 12:18 am
Not a noticeable difference in shifting, but definitely in chain life. My SRAM chain lasted 3500km, KMC lasted about 8000.
I'd take the KMC every time. I'm guessing the SRAM guy was just peddling his product (which is understandable).
PostPosted: Fri May 10, 2013 12:26 am
Interesting. Thanks.
PostPosted: Fri May 10, 2013 1:24 am
I can second that. I had a sram chain on it for a few days right when I got the yaw der. I swapped it out, and ever since then I've been on KMC. The diamond coat works wonders in longevity, too.
PostPosted: Fri May 10, 2013 2:49 am
Not to thread jack but 8000km on a chain is impressive! I've got 3700km on a KMC chain and it still looks new.
There are no new unread posts for this topic. moving to dura ace asymetric chain : shifting difference
Delorre
Thu Apr 14, 2016 11:53 am
toiyuet View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
19
1089
Sun Feb 19, 2017 7:54 am
Delorre View the latest post
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
677
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
There are no new unread posts for this topic. chain?
digitalintrigue
Fri Sep 09, 2016 11:38 am
peted76 View the latest post
There are no new unread posts for this topic. Chain lubricants
[ Go to page: 15 6 7 8 9 ]
wheelsONfire
129
13007
Mon Nov 28, 2016 1:23 pm
sawyer View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], kode54, mix123, poppiholla, Ritxis, wingguy and 29 guests
