It is currently Sat Jan 20, 2018 8:17 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu May 09, 2013 5:30 am
So I have a Pro Vibe Track Stem. It developed a crack on the Faceplate. Shimano won't sell me a new faceplate and I really love this stem. Anyone know of any places I could go to get this repaired?
NOW WITH MORE FLAVOR THAN KOOL-AID!
I'm 129 lbs! How's that for light!
PostPosted: Thu May 09, 2013 5:41 am
Buy a new stem. Problem solved.
PostPosted: Sat May 11, 2013 1:08 am
Find me a stem this stiff and I will. This stem is rare and works amazingly well, they're not that easy to come by.
PostPosted: Sun May 19, 2013 5:47 pm
Even though it's a track stem, does it fit standard road steerers?
PostPosted: Sat May 25, 2013 1:59 pm
These stems do pop up on ebay from time to time, both new and used.
Have you contacted shimano? They might know of this being an issue and will warranty it. Long shot but worth a call, or the LBS cold put a call in.
As an option what about the cavendish edition stem? Similar bulky design, not sure if it as stiff but should be stiffer then a normal stem.
Last what about having a machine shop make a face plate out of aluminum. 31.8mm bore with 4 drilled holes, slice in 1/2 and you have a new face plate (ok maybe not quite that simple, but you get the idea) A small shop with some good tools should be able to knock this out for you, it would not require CNC machining.
There are no new unread posts for this topic. Pro Vibe stem and handlebars
cho00010
Wed Jul 26, 2017 5:05 pm
djwalker View the latest post
There are no new unread posts for this topic. Pro vibe sprint stem decal removal
TomColnago
Thu Feb 09, 2017 11:23 am
TomColnago View the latest post
There are no new unread posts for this topic. Paging those with a Pro Vibe Sprint Carbon stem
tharmor
Sat Aug 26, 2017 4:06 pm
Ezra View the latest post
There are no new unread posts for this topic. Attachment(s) Shimano Pro Vibe Di2 stem's computer mount option.
Hexsense
34
4175
Sun Dec 31, 2017 9:50 am
reknop View the latest post
There are no new unread posts for this topic. Attachment(s) Paint Crack or Carbon Crack
ALAN Carbon+
27
3429
Sun Sep 17, 2017 8:23 am
micky View the latest post
Users browsing this forum: alcatraz, dmtevo, Google [Bot] and 35 guests
cron
