Returning a carbon frame to matt finish
xcnick
by xcnick
I have a friend who used a bit of t-cut polish on his matt black finished tarmac :shock: which gave it a shiny finish in this area! Does anyone know if this can be undone-I was thinking some of the finest wet and dry paper to take the shine off?
Cheers
HillRPete
by HillRPete
Yes in general, but making it blend in perfectly with the matte finish around could be hard.
Murphs
by Murphs
Yep, I think you would have to polish the whole frame, then re-matte it.
I think a scotch-brite pad would be better than wet&dry. They are available for industrial applications in different levels of abrasion
xcnick
by xcnick
Thanks guys. I should have mentioned it's only about a 3 inch section on the seat stay so not a huge amount. Will do a discrete test area!
prendrefeu
by prendrefeu
3M 2601 pads.
You don't need to do the whole frame, and blending will be easy. Whoever tells you that you need to do the whole frame over has never done finish work.
xcnick
by xcnick
prendrefeu wrote:3M 2601 pads.
Thank you :thumbup:
bura
by bura
+1
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
