It is currently Tue Oct 17, 2017 12:21 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sun May 05, 2013 3:11 am
Knee-over-pedal-spindle is simple. Other recipes for finding optimal saddle setback start with putting the bike in a trainer. I'd rather experiment on the road. What are the symptoms of the saddle being too far forward? What are the symptoms of the saddle being too far back?
Saura mon coeur que mon cul poise.
adapted from Rabelais
PostPosted: Sun May 05, 2013 3:18 am
why use another method if the knee over spindle is simple and works?
The New: BH http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=117760
PostPosted: Sun May 05, 2013 3:41 am
I find my body intuitively sitting in the right position even if my saddle is in the wrong place, hence if I shift the saddle too far back I'll end up sitting at its nose. keep shifting it front and back and try it out. Go for a test ride and stop frequently to adjust. Don't bother with fitting rules like knee-over-spindle.
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Sun May 05, 2013 3:42 am
Knee-over-pedal-spindle gives a result that works ok in practice for me. I'm not aware of any reason to believe that it gives the best possible result.
PostPosted: Sun May 05, 2013 6:03 am
Problem with knee of pedal spindle: imagine two identical riders but one has feet that are two sizes larger then the other. The only way to achieve the same leg joint angles on these two riders will be to have the saddle in two significantly different positions. One of these guys simply won't have their knee over the pedal spindle. It can work but be careful. A starting point at best.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Sun May 05, 2013 7:15 am
We've noticed an increase in positions a tad back from the KOPS idea. I'm probably a CM behind with good results.
PostPosted: Sun May 05, 2013 8:21 am
Moving back increases the involvement of the glutes and makes high rpm somewhat more difficult. Moving forward increases involvement of the quads and makes high rpm somewhat easier. Many road racers and century riders prefer a somewhat back from KOPS position especially if they do a lot of climbing.
I set mine by how it feels. I aim for involving the quads and glutes equally. I wind up about 1-2cm behind KOPS, on a standard 73 degree seat tube road frame.
Some articles:
http://sheldonbrown.com/kops.html
https://www.stevehoggbikefitting.com/bl ... oad-bikes/
There are no new unread posts for this topic. Need help finding a new frame
seaneT1
Tue Feb 07, 2017 11:18 am
seaneT1 View the latest post
There are no new unread posts for this topic. Help finding Argon18 E112 part!
smd13
Thu Apr 20, 2017 4:58 pm
PinaRene View the latest post
There are no new unread posts for this topic. Help with finding a replacement Canyon lower headset bearing
jimwhimpey
Tue Oct 03, 2017 9:43 pm
jfranci3 View the latest post
There are no new unread posts for this topic. Do you use a saddle bag?
survivor
34
1506
Sat Sep 23, 2017 11:51 pm
wicz View the latest post
There are no new unread posts for this topic. Can a Saddle Be Too Wide?
Valbrona
Mon Feb 27, 2017 8:36 pm
gtinut View the latest post
Users browsing this forum: Baidu [Spider], Google [Bot], Google Adsense [Bot], maccpres, pyrahna and 32 guests
