It is currently Sun Oct 22, 2017 6:57 pm
PostPosted: Sat May 04, 2013 5:42 pm
Hello
I'm lately (having raced the shoes for a month or so) expericing issues with my Sidi Wire with direct speedplay mount.
The problem is, that the clamp is pushing towards the hell, when i'm riding - making me have to stretch my legs more. What could the problem be? When i have ridden the shoes they will have pushed them selves as far down as possible?
Any one with similar problems, and a solution?
PostPosted: Sat May 04, 2013 8:17 pm
Sorry, of course i meant cleat. Not clamp.
Excuse me for me danglish...
PostPosted: Sat May 04, 2013 9:23 pm
well, if the cleat is moving, it micht be that the bolts are not properly tighten, so you should tighten then harder, or use some kind of anti-slide material in between cleat and shoe, like carbon grease or sanding paper, or much better, a very thin layer of rubber, like for instace a piece of an old tube, a very thin and light one, so the layer will be even thinner. Then tighten the bolts properly.
Happy Trails !!!
PostPosted: Sat Jul 16, 2016 3:37 pm
Bregne wrote:
Hello
I have Sidi Wire Carbon SP shoes and use those with Speedplay Zero Stainless pedals. A little Dynamic Carbon Assembly paste on the carbon sole, than the Speedplay Carbon Sole Protector kit and than the Speedplay Zero cleats on top of it. Tightened with a torque-wrench and you are good to go for a lot of pleasant km. on your bike.
https://www.remo-knops.com/cycling/
PostPosted: Mon Jul 18, 2016 12:45 pm
reknop wrote:
the torque wrench part is important. Too tight and you'll warp the cleat so it doesn't engage/disengage properly; too loose and it will slide around. Follow the torque specs that came with the shoes. Also, retorque periodically. I find that they can losen over time. A little Loc-Tite or equivalent can help.
PostPosted: Tue Jul 19, 2016 10:42 am
verbs4us wrote:
Yep, a good quality torque wrench is a must have for every home-mechanic.
One thing I still don't understand is why Speedplay keeps using bolts with a PH head ... :)
PostPosted: Tue Jul 19, 2016 11:15 am
one of my ratchets on my new pair comes loose all the time.. any way to fix this other than a new one?
Skunkworks Bikes
PostPosted: Tue Jul 19, 2016 1:44 pm
You've gotten all good advice. I prefer the carbon paste between the sole and shim. Then, I use blue loctite on the screws. Then I use the speedplay torque screwdriver (I know, too pricey for what it is but such is life) to tighten down. I lube the spring almost every other ride with a dry lube spray....but not too much of it. If you are entering and exiting the pedal easily, that diminishes the likelihood of the cleat slipping around. Good luck.
There are no new unread posts for this topic. Sidi Wire -vs- Gaerne G Stilo pretty unbiased
wheelbuilder
11
791
Wed Oct 11, 2017 2:37 am
wheelbuilder View the latest post
There are no new unread posts for this topic. Attachment(s) Sidi speedplay only white? Sidi 2018?
Tommo
11
783
Fri Oct 20, 2017 9:24 pm
avispa View the latest post
There are no new unread posts for this topic. Why no love for direct mount rim brake?
[ Go to page: 13 4 5 6 7 ]
ichobi
91
10984
Thu Sep 28, 2017 12:58 am
spdntrxi View the latest post
There are no new unread posts for this topic. Direct mount 1x chainring for Rotor 3D?
bkw
Sat Jun 03, 2017 2:13 pm
basurper View the latest post
There are no new unread posts for this topic. ee brakes direct mount - spare parts?
micky
Fri Apr 07, 2017 7:58 pm
kode54 View the latest post
Users browsing this forum: Baidu [Spider], blaugrana, faucon, merlinxlm, xpert, zank and 45 guests
