anyone know if a short cage sram force will fit a 12-30?
davidalone
by davidalone
I know, I know, calculate derailleur capacity and all that...
but I don't have time to get a new derailleur fitted and tuned before going to the mountains.
has anyone tried pushing their luck with a 12-30 on a sram force short cage derailleur?
how about a 50-34 and a 12-28? that seems to exceed derailleur capacity as well.
preludervtec
by preludervtec
I've gotten a rival short cage to work with my 12-30 Tiagra cassette. Just had to max out the B-Adjustment screw. In the end, I bought a Apex wi-fli RD so I wouldn't have to worry about it.
fa63
by fa63
12-28 works just fine, I'm using that right now with a compact crank. 12-30 might work, 12-32 does not from my experience.
eric
by eric
I used 50/34 and an 11-30 cassette with 2012 Red for some climbing races last year.
djconnel
by djconnel
May need to switch bottom pulley to 10 t, but should work. 32 may enemy work if lucky. Can also replace ramp screw with longer one, which may help. But probably okay. Better with 34-46.
Sent from my ADR6300 using Tapatalk 2
