It is currently Wed Jan 17, 2018 4:09 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri May 03, 2013 12:57 am
I'm with Miller you may not notice but you are probably holding the front lever causing The hold on thumb shiffer.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
PostPosted: Fri May 03, 2013 1:14 pm
Yes, I have had this problem and in my case it is always the operator. I rest my hands on the thumb lever just enough that it does not return completely. The rubber hood may also be holding it up too. I have the older SR and Chorus 11 and they both do it. I am putting the finishing touches on the SR EPS system and I am certain I will not have those issues.
Next time it happens, lift up on the lever, and watch it click in. Trim the hood if needed.
PostPosted: Fri May 03, 2013 11:44 pm
From what I remember on early comments on the new shifter system, the cable end will on occasion come out from its stop end within the shifter and this will lead to the shifter blocking / Not shifting. By shifting the opposite way the end is reset into its position and normal service resumes. Not a biggie as long as you know what it is and how to fix it, happens on occasion to any number of the ultrashift units I've been running over what must be 80k+ km of shifting.
PostPosted: Sat May 04, 2013 5:01 am
well, it didn't jam on today's ride. i did try to move the paddle while shifting with the thumb, and yes, it didn't allow me to shift the thumb button but i can almost say with absolute certainty that in my particular instance, i am not moving the paddle accidentally while trying to shift with the thumb button. i don't believe that is the cause of my issue. perhaps mr. tim is right, and it's something to do with the cable end instead.
PostPosted: Sat May 04, 2013 10:59 pm
I was looking for my post, but found that this is a new thread regarding an ongoing issue. I've had this problem. I found that my hoods are fairly worn and are now prone to rotating on the lever body as a result of grasping them with my hands. Rotation of the rubber hoods moves the cutout slot for the thumb shifter, thereby stopping it from returning fully to it resting position. Like other posters have mention; you cannot shift if the thumb shifter has not return to its resting position.
I just elongated and widened the thumb slot in the rubber hood. Haven't had a problem since. Note; This may not be the only reason why the shift mechanism is hanging up.
PostPosted: Sun May 05, 2013 4:02 am
I had the same problem when my 2011 SR was newer, but now it's quite rare. I called Campy N.A. and explained the issue. I was told 2 things: Check the hood alignment in relation to the thumb lever, and that while riding my hands put pressure on the shifters (thumb and finger levers) which causes the jamming. Campy told me to try shifting the opposite lever to free to jam.
I know the hoods are not a problem and my hand pressure is negligible. Honestly, if this many people are having the same issue there's a bigger problem going on. (Funny, I started a thread a couple years ago on this issue and no one had any experience with it?..)
PostPosted: Sun May 05, 2013 4:06 am
+1
Hood alignment or "user error" with regards to resting a finger on the shift paddle.
PostPosted: Wed Jul 17, 2013 8:01 pm
For some reason my newer 11sp shifter has stopped to lock up, I can't even lock it up on purpose.
The only thing I can think of is that it has new cables after moving around shifters.
The reason for moving around was that a spring broke in my older white SR 11sp shifter, the one that press the
shift lever against the brake lever.
In Spain Campagnolo changed everything except the rubber hood and brake lever (less than 2 week it took with freight back and
forth to LBS!)
The new mechanism is the newest one and that one works flawless too.
So now I'm a bit bummed that I cant track the problem down. (not really no)
If it ever comes up again I would definitely change the cable/wire to start with.
What did you come up with r_mutt?
Max Gravity, unfairly treated by gravity!
PostPosted: Wed Jul 17, 2013 11:44 pm
I have this with my 1997 Mirage kit. Seems like a design issue. Maybe try a grease?
Campagnolo; because it's a bicycle, not a fishing rod.
PostPosted: Thu Jul 18, 2013 10:30 am
@Devon
That's probably due to their age. They probably need a rebuild. The 11sp shifters have completely redesigned internals.
tommasini wrote:
+1
Agree about hood alignment fouling the path of the button.
I've also seen flash (excess material from the hood moulding) reducing the slot width. Bar tape thickness can slightly reduce the slot width as well.
If the button does not return to its home position before the lever is moved then the shifter can jam. It's easy to enlarge the slot by trimming some of the rubber away.
PostPosted: Thu Jul 18, 2013 10:44 am
Oh for sure, definitely due to age. Was just aiming to give a rounded view of all ages of the equipment, the issue is clearly an ongoing one.
PostPosted: Sun Jul 21, 2013 2:35 am
GASer wrote:
Same experience with my 2012 SR. Occurs from time to time and then goes away. I tried to lub the mech under the hood with some kind of WD40.
never use WD40 lube for the shifting mechanism. Only white grease or some sort of waterproof grease. If you have experience in rebuilding shifter , you can take it apart , clean , regrease. that's it. Most of the time its easier to just replace the whole body if its still under warranty.
I've seen the same thing as what Campy NA told you. Sometimes the hood will block the travel of the thumb lever. It doesn't retract fully and can cause the locking. You can fix the problem by cutting the excess rubber of the hood with an x acto blade till there is no interference.
Second thing is user error. people that ride with their thumb on the shifter paddle. That's a bad habit.
Third, the shifter is defective and is replaced under warranty. With the new ultra shift , Campy no longer has the parts available separately , so campy now sells the body with mechanism. Its a 5 minute job. Swap the brake lever and hood and your good to go. I see more defective shifters with SR than record or chorus.
PostPosted: Sun Jul 21, 2013 3:12 am
Just another data point - I have had this happen, very rarely. Typically resolved by flicking the button with my thumb, which points to the hood binding. Occasionally I think I've partially moved the paddle while flicking the button. I don't recall having to actually upshift to resolve it, but it's possible I've been through that scenario too. I would guess this has happened 6-10 times over 3.5 years and ~10k miles. Being in the drops is a different story - typically that's just a bad angle on the button with my thumb. Pushing forward and down gives you the illusion that it's stuck. I don't race so it's not a concern to me. [Edit - I'm on 2010 Record]
PostPosted: Sun Jul 21, 2013 11:30 am
I've been on 3 different camp super record or record bikes, all 2012 onwards, 2 of them had the exact same issue.
Dogma 6710g
PostPosted: Sun Jul 21, 2013 2:11 pm
CampagNOlo. ;)
There are no new unread posts for this topic. Campagnolo Super Record mechanical left shifter issue
wilwil
Fri Aug 04, 2017 9:06 am
wilwil View the latest post
There are no new unread posts for this topic. Dropped fork, rules of thumb needed!
Valy
11
1397
Thu Mar 02, 2017 10:37 pm
Valy View the latest post
There are no new unread posts for this topic. Di2 RD won't move at all.
merser
18
1652
Fri Jul 21, 2017 7:42 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Campagnolo Record/Super Record 11 Rev + Medium Cage
dudemanppl
Fri Aug 04, 2017 4:41 pm
joeyb1000 View the latest post
There are no new unread posts for this topic. Campy EPS ergo shifter
Bourquek
Mon Oct 16, 2017 3:47 am
avispa View the latest post
Users browsing this forum: Bing [Bot], gewichtweenie, Google Adsense [Bot], pyrahna, Yahoo [Bot], Zakalwe and 46 guests
cron
