It is currently Mon Dec 18, 2017 11:47 pm
Post new topic  Reply to topic  [ 83 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Fri May 03, 2013 1:49 pm
I found the Planet-X to be a bit of a compromise- quite difficult to keep centred and the stopping power wasn't fantastic (with Swisstop green). Light and cheap, though.
PostPosted: Sun May 05, 2013 6:48 am
Vuong05 wrote:
In terms of weight difference, my EE brakes were 190g vs 142g from the fibula (both weights are without pads).
Strange, as my EE brakes weighed 189 grams WITH pads. Where did you get that extra mass from?
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
PostPosted: Sun May 05, 2013 8:52 am
You are absolutely correct, that weight is with pads. Must have copied and paste the wrong weight when I made the post. The EE brakes are 169g without pads, so 27g heavier than the Fibula brakes.
PostPosted: Sun May 05, 2013 10:33 am
We've all made such mistakes. Speaking of THM Fibula brakes, one of the guys from Rolo bikes did an amazing job improving their looks!Image
RideWert.com
PostPosted: Sun May 05, 2013 4:22 pm
Big improvement.
PostPosted: Sun May 05, 2013 7:14 pm
Re: Planet X/Feather/Token brakes
aaric wrote:
Cons:
No quick release expander - have to use the threaded adjuster to clear some 25mm tires.
You know how the cable pinch bolt works right?
PostPosted: Mon May 06, 2013 4:13 am
:lol:
PostPosted: Mon May 06, 2013 8:06 am
That all black THM Fibula brakeset is the way it should have come from the factory. Looks so much better and makes an already cool setup that much better looking. I didn't have the guts to take the brakeset apart and just did the brake shoes and cable adjusters.
PostPosted: Mon May 06, 2013 10:10 am
Mod edit: Please do not spam thread with items for sale.
Shut Up Legs! (Jens Voigt)
PostPosted: Mon May 06, 2013 4:47 pm
Yeah, sure. Doesn't work well for me as I have to use the adjuster nut to get enough clearance to pull the cable out. Not a huge deal, but an annoyance compared with other brakes that you just flip the lever and they come out.
PostPosted: Mon May 06, 2013 5:10 pm
Hmm. I don't have that issue, but I guess if you liked having the pads very close to the rims I guess it may be a bit fidgety.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon May 06, 2013 5:27 pm
I find myself running the pads quite close to the brake surface with my Planet-X. For me, it counters the flex* I otherwise feel in the "QR" arm.
*I have yet to ride a pair of brakes that didn't have any flex. This doesn't mean they don't stop well. Different brakes just flex at different points. I found this adjustment gave me a much, much better feel about these brakes.
Current:
T2
Retired:
PostPosted: Tue May 07, 2013 5:44 am
Would you guys rate P-x brakes as good as DA or SR brakes in terms of stopping power and modulation?
PostPosted: Tue May 07, 2013 1:30 pm
I've got Fibula's, KCNC and AX3000 in addition to Red, Rival, SR11 and DA7900.
Favourites for performance alone are SR11 and Fibulas (both in the double pivot rear option) - both have the stopping power of DA7900 but with better modulation.
I'm getting grumpier and more pragmatic with age so now demand better performing brakes than my early WW days - only brakes that work nowadays.
The SR11's are on the century bike and the Fibula's are on the WW bike.
If I was an engineer and starting afresh I would definitely give the EE's a go - nothing but good reports - unfortunately I am an architect and I refuse to put something that looks like a toilet cistern fitting on my bike. Form follows function but there is a limit!
KCNC are great value for money but a little lacking in power and modulation - probably locked them up more than any other brake.
Ax3000 are surprisingly good for their weight but too fragile for me and just not enough stopping power for hills.
'83 De Rosa Professional |'11 Baum Corretto |'08 BMC Pro Machine >6 |'86 Pinarello Team |'72 Cinelli SC |'58 Bianchi |'71 Cinelli SC |'78 Masi GC |'83 La Redoute Motobecane |'94 Banesto Pegoretti |'88 Bianchi X4 |'48 Super Elliott |'99 Look Kg281
PostPosted: Tue May 07, 2013 7:37 pm
Ironically, Craig, owner of EE Cycle Works and developer of the EE brake, is also an architect by profession. :wink:
RideWert.com
There are no new unread posts for this topic. ee-brakes regular-real weight?
reedplayer
22
2277
Sun Apr 30, 2017 10:25 pm
reedplayer View the latest post
There are no new unread posts for this topic. Attachment(s) In a 2017 ww world - what is the weight penalty of running disc brakes?
alcatraz
Sat Mar 18, 2017 5:53 pm
nemeseri View the latest post
There are no new unread posts for this topic. New light-weight Recon cassette
tantra
Tue Sep 05, 2017 9:48 am
Delorre View the latest post
There are no new unread posts for this topic. Attachment(s) power2max NG fsa k force light weight
liketoride
Sat Aug 26, 2017 2:42 pm
liketoride View the latest post
There are no new unread posts for this topic. Light weight seat post collar?
stockae92
11
970
Fri May 12, 2017 6:49 pm
stockae92 View the latest post
Users browsing this forum: Bing [Bot], crn, Google Adsense [Bot], sooni, stormur and 32 guests
