Light weight brakes that really work!
rockdude
by rockdude
Several other reasons I like the EE's are
*ez to setup
*the engineering of these is really nice and they are well thought out.
*the customer service is great. Went you call them up, you talk to the owner/designer.
2 Serotta's, 1 Spectrum, 1 Van Dessel, 1 Parlee & 1 Carl Strong, & 1 Titus.
getting dropped
by getting dropped
I have a related question...
A friend is looking for some better brakes than his TRP 920SL brakes - he doesn't like their power, feels they are a bit lacking...not sure if he should switch back to say Shimano. (Uses Dura-Ace 7800 brake levers currently.)
With all the options out there, what is a better brake with good power [i]using the 7800 levers[/i] that doesn't cost a ton, and that is still reasonably light?
aaric
by aaric
I'd give the planet x brakes another vote.
Pros:
Cheap ($129shipped?)
Light (2 pair under 200grams / set with pads)
Good modulation
looks good
Cons:
Mashes the brake cable flat. If you don't mash the cable, the cable will slip under hard pressure
A bit finicky to set up. (Hints: You have to use a 4mm allen wrench to set the brake center as you tighten the bolt, and make sure to tighten down the cable clamp securely)
No quick release expander - have to use the threaded adjuster to clear some 25mm tires.
Cable can slip under hard braking if you don't make sure to smash your brake cable: I did this on my first test ride, and my lever went all the way to the bars...I could see this being a big issue if you don't tighten it enough, and then need a panic stop.
I'd classify them as having comparable performance to the original sram red brakes, at a much lighter weight, and better modulation.
I'm sure the eeCyclewerks ones are great, but their looks are a bit out there, and they cost a lot more.
RudyMontana
by RudyMontana
pawnii wrote:I hope the Gravitas brakes are not as bad as everyone here makes them out to be....mine just came in the mail.
They are a joke! They are in the process of being replaced.
RudyMontana
by RudyMontana
@Vuong05
What is the actual weight difference between the THM and the ee? How improved is the modulation on the ee, very noticeable? Thanks in advance.
RyanH
by RyanH
Pawnii:
I have the Gravitas and found them similar to the planet x. If you are using them with carbon wheels, get the new Swiss Stop black pads. If you want a scary experience, get some cork pads.
Strava
springs
by springs
juanacity wrote:Another vote for Planet X. A little fiddly to set up, but manageable and work really well once you get them adjusted. I'd be interested to hear if anyone has experience with them on any of the new wider wheels.
I use them with new Zipp 202 FC clinchers. No extra work to set up, and the wheels slip right out with no fuss. Will have to try Black Prince pads to solve some squealing issues with the Tangentes.
UpFromOne
by UpFromOne
Black Prince pads for carbon rims seem to improve alot of these brakes.
NiFTY
by NiFTY
Another vote for EE. Much better looking in person than in photos too.
Vuong05
by Vuong05
RudyMontana wrote:@Vuong05
I had the first gen EE with the upgraded bridge and I would say the difference in modulation is very small. If the EE brakes are a 10, I would say the the Fibula brakes are a 9. Minor, but just noticeable. In terms of weight difference, my EE brakes were 190g vs 142g from the fibula (both weights are without pads).
pawnii
by pawnii
RyanH wrote:Pawnii:
I have both Enve and Zipp wheels and they both say u have to use their pads or it voids the warranty.
Would love to try the Black prince pads
2012 Scott Foil Premium
Juanmoretime
Administrator
by Juanmoretime
I think the bake performance depends upon the correct pad for the rim type. On alloy I use Koolstop pads with my Gravitas SL's. With carbon rims, I ride carbon clinchers in season for training, I've been using Reynolds Blue pads.
The Gravitas SL's work great with the correct pad and I use I-Links for housing. There has never been a situation where I could not stop quickly and safely including high speed paceline riding with my team. There is never has been a time when I wanted more brake or felt it inadequate to anything else I have ever ridden. I trust my life daily to my brakes.
RESIDENT GRUMPY OLD MAN.
Saoi
by Saoi
The EE's have long been a wet dream; sadly, I have a hard time justifying that sort of cost for a set of brakes. The Far and Nears are a little easier to stomach, and probably where I'll go.
CBRE
by CBRE
UpFromOne wrote:Black Prince pads for carbon rims seem to improve alot of these brakes.
Im getting alot of squel with these pads although they do work well with the new Gravitas.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
sugarkane
by sugarkane
I wanted smart system wheels and my GSL brakes wouldn't work with em so EEs it was.. I wasn't sold on the look until I got a pair.. Hands down the nicest brakes monies can buy.
Who needs a pair of $600 brakes? Anyone who doesn't already have a pair :mrgreen:
