It is currently Wed Jan 24, 2018 11:11 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Tue Apr 30, 2013 4:51 am
looking for 700x18-25cc tube that is light'ish that has a black valve stem.
Check out my Instagram
https://www.instagram.com/nickarend/
-Pas Normal Studios
PostPosted: Tue Apr 30, 2013 5:07 am
Only one that comes to mind is mavic tubes.
PostPosted: Tue Apr 30, 2013 5:21 am
Yes, Mavic tubes have black stems, however you may have to do a little digging to find a verified weight.
PostPosted: Tue Apr 30, 2013 5:22 am
PostPosted: Tue Apr 30, 2013 10:02 am
Maxxis MVS Ultralight & Flyweight tubes are available with black valve stems.
PostPosted: Tue Apr 30, 2013 10:13 am
got that: 82 grams
PostPosted: Wed May 01, 2013 12:39 am
You could probably lighten that by drilling some holes in it!
PostPosted: Wed May 01, 2013 2:48 am
Black permanent marker.....
PostPosted: Wed May 01, 2013 7:39 pm
Works just fine :thumbup:
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Thu May 02, 2013 3:12 am
The Maxxis MVS tubes that 585 mentioned will be the lightest. Essentially 45g +/-, and the stem is aluminum, available in different lengths too.
PostPosted: Thu May 02, 2013 4:57 am
Any reason why valve stems cannot be made out of a polymer? Shear strength for hand pumps?
PostPosted: Thu May 02, 2013 5:33 am
How deep are your rims? Deep enough for short valve stem plus black extenders? That way you would not be limited to a brand with a black stem.
2012 SuperSix - 6.30kg
PostPosted: Thu May 02, 2013 7:04 am
What I found working better and with better looks than the permanent marker is a very tight black electrical tape use. One time tight around and the threads are still visible ,too.
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
PostPosted: Sat May 04, 2013 2:58 am
Heat shrink tubing is another option.
Not as light as marker though? :wink:
There are no new unread posts for this topic. Attachment(s) Black bike, yellow stem?
Alexandrumarian
21
1638
Mon Sep 25, 2017 4:24 pm
Alexandrumarian View the latest post
There are no new unread posts for this topic. Valve extender help
4ibanez
7
559
Sat Jul 01, 2017 6:29 pm
4ibanez View the latest post
There are no new unread posts for this topic. Grifo valve extension advice
alanmclean
Thu Oct 05, 2017 7:30 pm
alanmclean View the latest post
There are no new unread posts for this topic. Sealant and Valve Core Extension on High-Profile Wheels
Lightweenie
Fri Apr 21, 2017 11:52 pm
beatle View the latest post
There are no new unread posts for this topic. Attachment(s) Latex tube?
53cxzero
Mon Jan 08, 2018 1:58 pm
C36 View the latest post
Users browsing this forum: BdaGhisallo, benzebub, Bing [Bot], Google Adsense [Bot], karmaz, Lewn777, megl and 29 guests
