It is currently Tue Dec 12, 2017 1:38 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Sun Apr 28, 2013 5:28 am
Hi all,
Thinking of removing and install the bb30 bearing on my caad10 myself along with the hologram cranks.
Would of these would be the best tool to use?
http://www.enduroforkseals.com/id195.html" onclick="window.open(this.href);return false;
or
http://www.ebay.com/itm/FOCUSTEK-24-CHA ... 43b01aff1e
As for the argument of ceramic or steel, I would prefer the best quality steel bearing from $ pov. What brand/type would you suggest on this 6803 series?
PostPosted: Sun Apr 28, 2013 1:03 pm
I have the Enduro one and fully recommend it - simple and brilliantly engineered. Piece of cake to use.
PostPosted: Sun Apr 28, 2013 2:28 pm
I have one similar to this: http://www.enduroforkseals.com/id197.html
You should have proper bearing press too, like this http://www.enduroforkseals.com/id325.html
Those will make your life a lot easier.
PostPosted: Sun Apr 28, 2013 3:44 pm
VAR do a press that installs BB30 bearings as well as removes, if you like sexy French tools rather than American stuff.
PostPosted: Sun Apr 28, 2013 4:10 pm
Thank you for the help.
Does your combination offer better bang for the buck or alternative purpose?
As http://www.enduroforkseals.com/id195.html does both remove and press.
PostPosted: Sun Apr 28, 2013 4:12 pm
Thank you for helping.
I see the Var tool is about $170. Does it only do Bb30 or can it deal with PF30 as well?
Any other purpose for these three bearing tools? Can anyone of them be used to deal w/ wheel bearing so I can spent my $ wisely?
PostPosted: Sun Apr 28, 2013 6:13 pm
I believe the VAR BB30 press only does BB30. As said before, it removes as well as installs. Not sure if it does PF30. However, the other VAR press does do press fit, both all types of Campag press fit and also Shimano press fit.
I am not aware of the existence of any single tool that will press everything there is on the market.
Cyclus Snap.In has adapters for press fit.
PostPosted: Mon Apr 29, 2013 1:52 am
The important thing is to try not to make the BB30 creak.
PostPosted: Tue Oct 29, 2013 11:35 am
There is most important tools are auto repaired tools you can used these tools on your bike bearing repaired thanks...http://www.bearings.uk.com/acatalog/6902_Bearing.html
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. Online Frame Comparison Tool??
EvilEuro
16
887
Thu Jul 20, 2017 11:58 pm
silvalis View the latest post
There are no new unread posts for this topic. Di2 battery drainage / diagnostics tool
wheelsONfire
7
1050
Fri Apr 14, 2017 2:26 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Attachment(s) Colnago C60 Bottom Bracket Tool
thebman
35
2517
Mon Jul 17, 2017 2:54 pm
thebman View the latest post
There are no new unread posts for this topic. Attachment(s) Help using the Campy UT-FD120 Tool with pics
Bourquek
7
769
Wed May 10, 2017 11:57 pm
BRM View the latest post
Users browsing this forum: calleking, csteeds, Exabot [Bot], kookie, lovemyway, r_mutt and 30 guests
