It is currently Tue Jan 23, 2018 11:10 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Sat Apr 27, 2013 10:59 pm
Hi everybody,
I have 2 bikes, one for the good days and road races (Cervelo S2 with 404 tubs) and one for training and commuting (Caad9). They are both size 54 with a 110 stem. They have identical saddles, stems and handlebars.
The Cervelo fits me like a glove, the Caad9 feels enormous.
I think the Caad9 isn't compatible with my body (long torso, relatively short legs). I just can't put the power down. Feels like Star Trek! I'm 177cm.
I was wondering if anybody could help. What's the closest Canyon Ultimate CF match (in terms of geometry) to my S2 size 54 with 110 stem? A Canyon CF size 54 or a 52? With a 100 stem?
Thanks heaps!
PostPosted: Sat Apr 27, 2013 11:38 pm
use stack and reach; and questions like this are easy:
Cervelo S2 54 - 541, 380
Canyon CF 52 - 547, 387
Canyon CF 50 - 532, 386
Cannondale 54 - 546, 383
So really, the cannondale shouldn't feel that much different, 5mm higher, 3mm longer. And the Canyon may not solve what you are looking to solve...
PostPosted: Sun Apr 28, 2013 11:51 am
Thanks for the kind reply!
I'm a bit puzzled, probably due to my lack of understanding, how can the Caad9 feel so big compared to the S2? I wish I understood how geometries really work...
PostPosted: Sun Apr 28, 2013 6:36 pm
the caad 9 has a practically horizontal top tube, with a bb to top of seat tube measurement of 55 cm, the cervelo's is 51 cm with quite a steep slope
what make the cannondale feel big is the higher standover height
could it be that the cannondale has this 2,5 cm top headset bearing cover and the cervelo a lower one ?
in any case the canyon has about the same degree of sloping as the cervelo, so should not feel big with comparable stack size
what are your own critical body measurement btw; overall height and inseam ?
PostPosted: Mon Apr 29, 2013 8:52 am
Thanks for your kind reply too.
I don't have those two measurements at hand but from memory my overall height is 177cm. Both bikes have the stem slammed, both headset covers are very tiny.
Please see below the notes from the latest bikefit assessment (1 year ago, done on the Cervelo S2, fit perfectly before the bikefit and even more perfectly after the fit! magic).
Your position details are as follows: Saddle Height: 733mm, Saddle Setback 59mm, Reach to the Bars (Horizontal): 528mm, Reach to the tip of the levers: 684mm, Drop from saddle to bars: 107mm. Horizontal Reach from BB to Bars: 474mm, Vertical Stack from BB to Bars: 602mm. Cranks: 172.5mm, Bars: 40c/c (Deda Zero 100 42s), Levers: Sram Red (Old shape), Saddle: Selle Italia SLC, Pedals: Look Keo
Does that mean that:
1. The Canyon Ultimate CF geometry is similar to the Cervelo S2 (old R3) geometry
2. The closest match to my Cervelo S2 is a Canyon Ultimate CF size 52?
3. The Caad9 size 54 is considerable larger then the Cervelo S2 size 54, hence the feeling of cycling on a 'massive' bike
PostPosted: Mon Apr 29, 2013 2:26 pm
1) yes, stack height and seat tube lenght are almost identical
2) if you include seat tube height yes, if you don't they are almost identical
3) the caad's stack height is the same as the two other's it is just the seat tube being longer which makes it feel larger
when standing over the top tube there's more room to your gentle parts with the cervelo and the canyon than with the caad 9, but the handlebar on the three will have the same height
looking at your measurements 54 cervelo / cannondale and 52 canyon are 'your' frame size
PostPosted: Mon Apr 29, 2013 3:22 pm
Thanks again GT56.
Unfortunately the Canyon CF 52 is out of stock at the moment...
Will give them a call!
There are no new unread posts for this topic. Canyon Ultimate CF SLX - Frameset weight
nonamed
10
2186
Fri Oct 27, 2017 12:18 am
robertbb View the latest post
There are no new unread posts for this topic. Buying Canyon frameset in Germany - bringing back to the US
mattiTWOROADS
Tue Sep 26, 2017 9:38 pm
Ginsterdrz View the latest post
There are no new unread posts for this topic. Canyon CF SL(X) Disc tyre size
Roel W
Sat Dec 09, 2017 8:58 am
hannawald View the latest post
There are no new unread posts for this topic. Size advice Cervélo R5 (not the new one)
machadok1
13
1148
Thu Jul 13, 2017 2:02 pm
machadok1 View the latest post
There are no new unread posts for this topic. New bike advice: Cervelo, Look, Canyon
Lookryder
10
1610
Mon Aug 07, 2017 4:50 pm
TiCass View the latest post
Users browsing this forum: Bing [Bot], bobones, BuLi84, Google [Bot], Sjoerd, wobbly and 37 guests
