Shimano Ultegra 11 speed
davidalone
by davidalone
Liggero wrote:
davidalone wrote:
havana wrote:I fail to understand Shimano's crank strategy. No BB30, weird 4-arm design, assymetric blades, no 110mm 39T blades, etc, etc.
shimano does not do BB30 because they do not believe that BB30 is a superior standard. they have argued this before, and as a mechanical engineer, their argument does have merits. BB30 gives you a tiny and, to a human, imperceptible increase in stiffness for much much higher complexity in maintaining the system. you get smaller Q factor, yes, but that is not a good enough reason IMO. it is, technically more robust to the elements than outboard bearings, but they are a PAIN to replace if something goes wrong. outboard cransk are much easier to replace, more versatile, and less likely to damage your frame on installation. same goes for PF30, and to an extent, BB86 and BBright as well. shimano will also make less money. so I DO see why they would not support BB30.
BB30 is popular among frame manufacturers because it saves them money. it's much faster and cheaper to purchase an OE spec bearing and press it into the fram than having to machine out steel threaded inserts and bond them into frames. it's a simple case of frame manufacturers versus shimano here. but shimano is sticking to their guns and as the major industry player, they have evrey right and clout to do so.
the 4 arm design may LOOK weird, but it offers tangible engineering benefits. the 4 arm design has been on shimano MTB cranks for awhile now. 4 arms are lighter than 5 arms, and shimano claim that the crank still retains the same level of stiffness. in addition, the new 4 arm design makes 110 or 130mm BCD pointless. you can put a 50-34 on that crank. you can also put a 53-39 on the very same crank. this is a game changer. cuts down inventory that stores need to hold ( you don't neeed to carry both compact and standard cranks anymore.) it also streamlines manufacturing. these savings may eventuaklly be passed down to the consumer if enough people follow their 4 arm standard and make chainrings for 4 arm cranks. ( shimano chainrigns are great but exoensive.) the problem here is that most other crank or chainring manufacturers are 5 arm, so they are trying to revolutionize the game here. My feeling is that this is a real game changer. once you get used to the 4 arm design, it actually looks pretty cool.
the new crank is certainly an impressive bit of techy kit and I'll be trying to get my hands on one as soon as ultegra 6800 comes out.
4 arms road crankset, for compact and no compact is a great idea if you use shimano expensive hollow chainrings. Those chainrings are very stiff, and they are extremely expensive to produce for shimano, imagine how expensive they would be for another manufacturer who won't produce a few millions of them... Quite a big shit is what i would call these new cranks. Not only that they are ugly as hell, but that they make 3rd party rings kind of impossible.
It's amazing to me how some people has such a little engineering manufacturing knowledge, and still write these pointless opinions with no reservations... welcome to planet earth i guess...
I'll have you know I am a mechanical engineer. I do know about manufacturing. I was putting it in understandable terms for those that MIGHT not understand. so before you spout off such accusations, get off your high horse. we might differ on opinion, but I challenge you to completely say that my post has completely no basis and no grounding in engineering knowledge.
shimano uses a special cold forging technique to make their chainrings. only shimano and praxis works forge their chainrings, which is inherently better than CNC machining for chainrings because of the grain alignment in the metal making a stiffer chainring. the start up cost for forging is REALLY high, which is why very few industry players use it. on a per unit cost basis, it actually isn't that expensive once your machines and tooling have been paid for.
the 4-arm design's main advantage is the ability to swap out the wide range of chainrings. weight savings and stiffness? minimal impact.
yes, it makes sense for a manufacturing point of view to just make one BCD pattern crank. it also makes sense for consumers and shops who have to keep less inventory on hand. But it is a business risk as it alienates aftermarket manufacturers from making compatible chainrings ( I'm not sure if shimano have patented the 4-arm design, or if they wish to license it.) . it's not a really big risk, as they are the biggest industry player, but it is still a risk.
lemond853
by lemond853
I just read on bikerumor (http://www.bikerumor.com/2013/04/30/11- ... 800-group/) that the cog thickness on the 11 speed cassette is the same as the 10 speed.
Does this mean that you could modify 10 speed cassette spacers to get 11 speed spacing? I'm not sure that you'd have enough room on a current freehub to get 11 cogs on there. But it may give you an option to keep using 10 speed cassettes and hubs and slowly transition to 11 speed.
Scott
sigismond0
by sigismond0
Yes, the main difference between 11s and 10s is the spacing. They're packed a little more tightly together but have the same thickness, so you could sand down the spacers where applicable to make a homebrew 11s cassette. This might be a little tough though unless you have a loose cassette. The top end cluster is usually built together on a block that might not allow for spacing modification.
Horze
by Horze
Why BB30? You don't want it.
Shimano's standard is preferred in my view and experience.
Caveat. There's more to a crankset than stiff BB spindle. Arms, rings, and I don't just mean shifting quality either.
7x Forum Racing Ban Champion.
Tinea Pedis
by Tinea Pedis
Exists
http://instagram.com/p/Z1lpt1ilMY/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
And it's nice.
Few other shots
http://instagram.com/p/Z1okT6ClBe/" onclick="window.open(this.href);return false;
http://instagram.com/p/Z1qF2pClDp/" onclick="window.open(this.href);return false;
http://instagram.com/p/Z1p040ilDX/" onclick="window.open(this.href);return false;
sigismond0
by sigismond0
Tinea Pedis wrote:Exists
And it's nice.
Of course it exists. Shimano announced it a while back and left demo units in industry hands. Expected release is September.
Tinea Pedis
by Tinea Pedis
I must have missed all the pic's of it on bikes, starting to appear at trade shows and such in here then.
I was using a figure of speech.
But bravo anyway.
MichaelB
by MichaelB
I wanna see pics of the hydraulic disc version.
Actually looks better in the two tone grey compared to the black/silver of the DA version
CBJ
by CBJ
I agree it looks really good. It will be interesting to see what the weight difference will be.
Tinea Pedis
by Tinea Pedis
Looks are always subjective, I prefer the 9000 crank.
That said, the Ultagra RD is very nice.
sigismond0
by sigismond0
Oh yeah, the 9K crankset is insanely beautiful. This is about the next best thing though, at least for those of us that can't afford to go up that one last level.
photocycler
by photocycler
was hoping for a larger cassette option - I would have thought they would have a wifli competitor by now as its becoming more common to run a 30+ cassette for the hilly regions
virenque
by virenque
Shimano has a GS version of both Di2 and mechanical that supports up to a 32 on the rear with a 11-32 cassette option available
Ghost234
by Ghost234
photocycler wrote:was hoping for a larger cassette option - I would have thought they would have a wifli competitor by now as its becoming more common to run a 30+ cassette for the hilly regions
If you need more than a 34 + 32T, something is wrong.
There isn't too many sustained 20+% grades out there.
