It is currently Sat Jan 20, 2018 8:42 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Apr 26, 2013 5:47 pm
I had it happen a couple of times, but not during shifting, I stumbled during a stop and back pedalled or something.
Anyway the chain dropped pass the catcher and I was not able to get it back over the catcher onto the ring unless I remove the catcher. I imagine this would be an issue if I don't have a 2.5mm key with me.
I set it about 1/2 mm in the biggest cog, if I set it any closer I think I would hear it rub when actually pedalling.
The thing seems to me is that it won't drop in the biggest cog but if the chainline is on the smaller cogs I think the chain can just slip thru. It is not as tight as the k-edge ones where it is trying to touch the chain ring bolt.
PostPosted: Fri Apr 26, 2013 6:37 pm
Did you use the adjuster stop screw to set the position, or just tighten down the mounting screw with it in position? If it's the latter then it can slip when there is force on it.
I've had the chain come off and get caught by the catcher. Usually when shifting at low speed. It hasn't gotten past the catcher but it has caused the derailleur to go slightly out of adjustment.
PostPosted: Fri Apr 26, 2013 6:49 pm
yes I have the set screw pressing on the tab
PostPosted: Fri Apr 26, 2013 7:20 pm
Get a chain catcher to back up the chain catcher?
PostPosted: Fri Apr 26, 2013 7:28 pm
I've never had my chain drop past my Sram catcher while riding.
But I did have it happen while the wheels were off my bike in the back of my car on the way to a race.
The way to get it back, without an allen key, is to use 5 or 6 links of the chain to "bend" around the catcher by taking the bend through the chain rings, from the inside to the outside, so as to bypass the catcher.
Hope that makes sense and helps.
Cheers
GJ
PostPosted: Fri Apr 26, 2013 8:03 pm
Thanks, do you mean take extra links from behind the catcher, or in front of the chain ring?
PostPosted: Fri May 10, 2013 4:38 am
I've had it happen once on the road but was able to get it back past. What I have found is that the epoxy type paint used on the derailleur holds up under initial adjustment but when you do ultimately drop a chain with force into it, the force causes the adjustment screw to actuall dig in to the paint and cause more gap then desired. Once I re-adjusted it after that it's been fine. I was in a smaller cog when it happened.
There are no new unread posts for this topic. Chain catcher issue.
bura
13
1421
Mon Apr 24, 2017 3:25 pm
AJS914 View the latest post
There are no new unread posts for this topic. Chain drop issue
JBeauBikes2
16
1221
Mon Jul 17, 2017 8:34 pm
JBeauBikes2 View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
25
3097
Sat Jan 06, 2018 9:49 pm
spud View the latest post
There are no new unread posts for this topic. Sram etap FD chain drops
felshampo
Wed May 10, 2017 6:19 pm
felshampo View the latest post
There are no new unread posts for this topic. SRAM etap chain length...
addicted
Thu Apr 27, 2017 2:01 pm
ergott View the latest post
Users browsing this forum: alcatraz, Bing [Bot], bobones, iamalex, sovereign, wedgie and 43 guests
cron
