0-SB Carbon Seastpost - Need Suggestions
rijndael
by rijndael
I need a carbon seat-post with 0 setback. There are a lot of them out there, but almost all of the ones I've seen take up too much real estate along the rails (front to back). When they're too wide, I can't get the saddle where I want it (nose to BB setback).
I need something like the Bontrager XXX Race seatpost, but they don't come in 0 setback.
I'd appreciate any suggestions.
It's the last piece I need to finish out my new EVO:
bikerjulio
by bikerjulio
I have a Token superlite. Mine's oversize for my regular SS but I think your bike takes a 27.2mm?
One source http://www.tufonorthamerica.biz/index.php?main_page=product_info&cPath=2_100&products_id=632
Graphics came off with some 800 and 2000 grit paper. It's 350mm long so can be cut down safely too.
There's sometimes a buggy.
One.
rijndael
by rijndael
That looks a lot like the Q2 post I have in the garage, which is too wide.
Do you mind taking a measurement from the back to the front of the clamping surface?
rijndael
by rijndael
Someone pointed me to Enve, and that looks like a winner.
deermatt
by deermatt
the bontrager xxx lite comes in a no setback, ive been using one on my supersix. Im getting rid of it actually because I just bought a fm066sl frame that takes a 27.2 seat post.
kya
by kya
If I recall correctly, a Ritchey 1-bolt post would be a bit lighter than the Enve post, this being weight weenies and all.... Clamping area isn't overly wide either.
I gave my post to my father so I can't go and weigh it, but I think my 27.2 post weighed in at something like 150-160g?
Stolichnaya
by Stolichnaya
3T Ionic O... ?
rijndael
by rijndael
Stolichnaya wrote:3T Ionic O... ?
Yes! Thanks, I found that one last night.
rijndael
by rijndael
deermatt wrote:the bontrager xxx lite comes in a no setback, ive been using one on my supersix. Im getting rid of it actually because I just bought a fm066sl frame that takes a 27.2 seat post.
I'm not seeing a 0 SB option listed here, under the details tab:
http://www.bontrager.com/model/00286
rijndael
by rijndael
kya wrote:Ritchey 1-bolt post would be a bit lighter than the Enve post
I like lighter, and it's cheaper.
Between the Ritchey, 3T, and Enve - are they all about equal in terms of clamp adjustment and ease of setup?
Barrie
by Barrie
Why carbon ? I have the same frame as yours with an Alloy seatpost 116g .£64 + £10 P/P
http://www.ebay.co.uk/itm/6KCycles-Ultr ... 43bab6bd75
Barrie
rijndael
by rijndael
I need to replace the one I have on there now, so I may as well get a carbon one.
I have an extra Q2 post, which has a mount like the one you've linked to, and it's too wide.
rijndael
by rijndael
rijndael wrote:Between the Ritchey, 3T, and Enve - are they all about equal in terms of clamp adjustment and ease of setup?
From my research, the 3T's DiffLock is adjustable in .5 degree increments.
GT56
by GT56
http://www.bontrager.com/model/00286" onclick="window.open(this.href);return false;
bontrager on a cannondale is blasphemy anyway
what about fsa ?
and then of course there are ritchey, easton, 3t, syntace
rijndael
by rijndael
GT56 wrote:bontrager on a cannondale is blasphemy anyway
LOL. I was going to remove it, if I went that route.
Syntace and FSA won't work, based on some pics I found of them.
Easton could work, but I think they're heavier than the other options.
