Old Dura Ace / Lightweight to Campag 11 Can any one help?
benkc1984
by benkc1984
Hello.
Can anybody help me, I have just purchased a set of Original Dierl & Obermayer Lightweight Wheels with Dura ace 7700 Hubs from Ebay:
http://www.ebay.co.uk/itm/Lightweight-Carbon-Tubular-Wheels-Wheelset-Continental-Tyres-Shimano-8-9-10hub-/290898826441?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWNX%3AIT&nma=true&si=WQ8C1XC6%252FqI1Z6GTsmUZ%252BGJIGOk%253D&orig_cvip=true&rt=nc
I would like to run Campagnolo Super Record 11 Speed EPS groupset on them.
Does anyone know if there is a Freehub that will allow this on Shimano 7700 hub?
Or is there a 11 Speed Campagnolo friendly Cassette that will drop onto the Shimano Freehub?
Thank you in advance.
BeeBee30
by BeeBee30
I'd like to add that I have the exact same wheels and wonder what my options are to run Dura ace 11?
Ti or dye!
N.T
by N.T
carbon sports can refit a dt 240 hub to that and that will enable you to run what you want.
Fuelled by kofein
borja
by borja
I think these are DT240s hubs. If so you just need a DT Campy rotor.
For DA 11 speed you need to get a 11speed conversion kit - new 11speed rotor and the washer on the left side.
BeeBee30
by BeeBee30
They are Dura Ace 7700 hubs.
Ti or dye!
benkc1984
by benkc1984
Thanks for the help N.T, i was not aware that Carbon Sports could do that, it sounds expensive but the only way.
Cheers, Ben.
Cipollini RB800 - Cannondale Super Six Evo HM - Ritte Bosberg - Kona Paddywagon
sedluk
by sedluk
They don't look like DT Swiss hubs to me. It was my understanding that they had Tune hubs. If that is the case maybe Carbonsports can change them to a Campy Tune hub.
thisisatest
by thisisatest
The rear is definitely a Shimano hub, or at least the freehub body. I was not aware Lightweight ever did that, I thought it was always Tune or DT.
But it's not a 7700 hub either. It's a 7400-series hub. It is compatible with up to 10speeds, but NOT compatible with any cassettes with an 11tooth first cog. Must start with a 12 or larger.
phallenthoul
by phallenthoul
mail Lightweight. they're very responsive and helpful according to my experience.
