It is currently Mon Jan 22, 2018 11:19 pm
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sat Apr 20, 2013 6:10 pm
I've been offered recently an used Specialized Srm, donno the exact year but has same stickers as the one used by Astana in 2010 (see below photo).
I wanted to know if early model of Specialized Srm use the same specs as the Lightning cranks, which would meant I could use it also on a BSA frame.
By looking at info in here, it seems that Specialized and Lightning cranksets were similar till 2011, but from 2012 the big S changed design.
My current ride
PostPosted: Sat Apr 20, 2013 7:13 pm
The 2010 models still offered an English BB which was discontinued in 2011, which may explain how the SRM was mounted.
PostPosted: Sat Apr 20, 2013 9:40 pm
So that would confirm that the Lighting BSA BB could fit?
I mean like this one... http://www.lightningbikes.com/cranks/bb-cup-types.html ?
Cheers
My current ride
PostPosted: Sat Apr 20, 2013 10:35 pm
NO! been there done that, specialized spindle is OSBB length which is about 20mm (i forget the exact figure) too short. You can bodge it with a lightning crank on the spider, but the spider is offset away from the frame too far, and is rotated about 18degrees, meaning that one chainring bolt is partially obscured by the crank arm. Don't do it unless you have a proper BB30 native frame.
There are no new unread posts for this topic. power meter Q again, compatibility
Boshk
Mon Jul 24, 2017 5:31 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. 9170 shifters compatibility
hannawald
Mon Oct 23, 2017 11:22 am
hannawald View the latest post
There are no new unread posts for this topic. I find the lack of compatibility disturbing
jlok
Sun Mar 05, 2017 10:32 am
jlok View the latest post
There are no new unread posts for this topic. Praxis Zayante Crankset - BB compatibility
Stolichnaya
Sun Aug 27, 2017 1:14 pm
Attermann View the latest post
There are no new unread posts for this topic. Campy Potenza Shifter compatibility
nthanach
9
1160
Thu Jun 08, 2017 8:32 pm
kervelo View the latest post
Users browsing this forum: Chris3g, dricked, euan, JoshMA87, Miller, trimenc and 43 guests
