It is currently Wed Jan 17, 2018 2:24 pm
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: fm028/29 isp topper
PostPosted: Sat Apr 20, 2013 9:26 am
Looks like I'm getting a dengfu fm029 isp frame soon.
having done a search it seems the isp topper is a bit rubbish. Having looked around the outer diameter of the isp is 37.2mm can anybody tell me which lightweight alternative I can buy or confirm what you have on your dengfu bike?
 Post subject: Re: fm028/29 isp topper
PostPosted: Sat Apr 20, 2013 12:11 pm
I use one of these frames. The drawing shows 37mm, but I've not measured the top of my seat tube. And ... after lots of looking I have not been able to find a better alternative.
PostPosted: Sat Apr 20, 2013 12:46 pm
Toppers from 2 manufacturers may be suitable:
PostPosted: Sat Apr 20, 2013 1:34 pm
Problem is that it's an oddball size.
Re. Woodman, I contacted them last year and they told me that 34.9 was the only size currently available.
Of course that could have now changed.
PostPosted: Sat Apr 20, 2013 1:41 pm
@brearley
are you sure it's 37.2? It seems to be a strange size.
PostPosted: Mon Apr 22, 2013 7:57 am
Anyone know if the Ritchey WCS 1-Bolt Mast Topper, 38.35mmx70mm fits this frame? That's the same size as the largest Tune Cappy. Maybe it needs a shim?
PostPosted: Mon Apr 22, 2013 10:02 am
Any aftermarket ISP toppers need to be shimmed, eg with sheets cut out from cans. Which will increase the chance on seatpost slippage. I kept the original topper because of this. Problem is, it has too much setback for my liking. Grrr
PostPosted: Mon Apr 22, 2013 4:40 pm
KCNC Majestic
@racecarbrian
PostPosted: Mon Apr 22, 2013 5:24 pm
If the diameter is the same as the fm015, then you 'can' fit a kcnc, but it requires significant dremmeling. I wouldn't recommend it.
PostPosted: Tue Apr 23, 2013 12:14 am
Good product to make then and sell to all the FM028/9 owners out there. I ride an s-works tarmac and a ridley helium and I want to try one of these frames after reading all the chinese carbon threads. So curious how it will compare.
PostPosted: Tue Apr 23, 2013 6:11 pm
I should be finding out when my frame will arrive soon then after painting I will see whether the weight saving between the standard and ritchey one is big enough. Setback won't be an issue for me just depends on weight savings.
Buying this as a race bike so I'm hoping its plenty stuff and handles well.
There are no new unread posts for this topic. Emonda SLR Seatmast topper
synthesis
Mon Jan 08, 2018 3:58 pm
Fisherfreerider View the latest post
There are no new unread posts for this topic. Integrated seat mast topper
JohnnySea
Tue Jun 27, 2017 3:11 am
shimmeD View the latest post
Users browsing this forum: Bing [Bot], Chris3g, coriordan, crux, dricked, Google Adsense [Bot], Yahoo [Bot] and 44 guests
cron
