It is currently Tue Jan 23, 2018 1:18 pm
PostPosted: Fri Apr 19, 2013 3:46 am
SO I have a Shimano Di2 9070 Internal Battery BTR2-1. It came with the battery, a few washers and clip, and two plastic wedges. Does anyone have any creative ideas to mount this in a Thomson seat post?
Thanks in advance
PostPosted: Fri Apr 19, 2013 4:00 am
Some folks have done foam, some just rubber o-rings. I wrapped electrical tape around both ends until it was thick enough to be nice and tight and stuck it in there. I don't think it really matters as long as you get it to stay in there. Worst case scenario it falls down into to seat tube.
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Fri Apr 19, 2013 6:40 am
Some kind of foam is the easiest way to go, here's how I did it, super snug fit and wont move a millimeter.
PostPosted: Fri Apr 19, 2013 6:42 am
Is that foam? Looks slick! Where can I get some of that?
PostPosted: Fri Apr 19, 2013 6:53 am
yeah, got it at an home center/DIY store here in japan. Usually for protecting furniture when you move, so it as a slight sticky back, no need for zip ties or anything. Although I had to put the whole seat post in the freezer before I manage to remove the battery (to take the pictures) but, wont need to remove again it until the battery brakes, or change of seat posts.
Super light solution too, only added 4 grams to the battery.
PostPosted: Fri Apr 19, 2013 7:11 pm
Just installed the internal battery in my Alize. The seatpost is streamlined so no room in there. Dropped it down seat tube and before I installed PF-BB had access from bottom. Then wrapped it in double side tape and secured tape with zip tie which I didn't cut the end off. It will sit between BB and derailler. New install so not sure if it will make noise over bumps. Was able to get it out by pushing on bottom and pulled with metal coat hanger . Was scared once I dropped it in that I would never be able to pull it out but not so. m
PostPosted: Sat Apr 20, 2013 9:39 am
What is the diameter size of this round battery?
PostPosted: Sat Apr 20, 2013 7:25 pm
My LBS used some sort of 3rd party foam mountain bike handle thing hanging on the sales display as padding, really solid fit, it's not going to go anywhere! Seatpost is a Bontrager xxx
Riding my road bike in North Wales
http://www.strava.com/athletes/keith_robertson
PostPosted: Sun Apr 21, 2013 6:19 pm
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Mon Apr 22, 2013 7:11 pm
I took an ESI grip, Cut it down and shaved it a little and used that to shim my post and hold the battery, worked great.
I tried to take a pic, but I couldn't light it right.
There are no new unread posts for this topic. Shimano SC-MT800 display compatible with SM-BTR2 Battery?
velobob
Thu Oct 26, 2017 8:42 pm
egebhardt View the latest post
There are no new unread posts for this topic. EW-WU111 with a SM-BTR2 battery for only ANT+?
Gearhead65
10
1797
Tue Mar 07, 2017 8:05 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Can I add a new 9150 Di2 Battery with blue tooth to my 9070
mnmasotto
Sat Mar 11, 2017 9:23 am
TurboKoo View the latest post
There are no new unread posts for this topic. Cervelo S3 2014 - Internal battery conversion
Xcessiv
Wed Feb 15, 2017 12:01 am
hambini View the latest post
There are no new unread posts for this topic. Shimano 11-30 cassette with 9070 Di2
mnmasotto
7
984
Tue Sep 12, 2017 3:24 pm
MXGimp View the latest post
Users browsing this forum: gerryc89, Johnnysmooth, KCookie, morganb, wingguy and 40 guests
