It is currently Mon Feb 20, 2017 2:39 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Ax lightness brakes
PostPosted: Thu Apr 18, 2013 8:14 pm
I bought these brakes and i have the powercordz but the clamp is not going to be in for 3-4 weeks and i wanted to run them with the steel cords until the clamps come in but last night i had the hardest time having the clamp stay, after a couple of pulls it would fall down. There is pic all over the place for how to install with the powercordz and i will be needing that but there is none for the steel cables that i could find on the searches. i was wondering if anyone has something that would help me. Right now the clamp bolt is slipping down. I only started looking at it last night so i was going to go home today and really look at it. Any help would be great thanks.
 Post subject: Re: Ax lightness brakes
PostPosted: Thu Apr 18, 2013 8:36 pm
Make sure you do not have the clamps upside down..
PostPosted: Thu Apr 18, 2013 9:28 pm
i have the big hole up, is that upside down?
PostPosted: Fri Apr 19, 2013 2:27 am
Sounds like you have it upside down, the big hole should be down. That way the clamp bites into the cable as it tries to get pulled through.
PostPosted: Fri Apr 19, 2013 2:28 am
And make sure to use a torque wrench when tightening.
PostPosted: Fri Apr 19, 2013 3:54 pm
thank you.
There are no new unread posts for this topic. Anyone running an Edge 1.0 fork with AX Lightness brakes? Clearance for 25 tires?
jz4nyc
Fri Jul 15, 2016 1:29 am
jz4nyc View the latest post
There are no new unread posts for this topic. Attachment(s) Ax lightness vial evo experience
Naturel
11
1437
Fri Jan 06, 2017 2:01 pm
sakattack View the latest post
There are no new unread posts for this topic. Attachment(s) Ax-lightness Vial EVO Race build
sp3000
Sun Feb 19, 2017 7:47 am
sp3000 View the latest post
There are no new unread posts for this topic. ax-lightness VIAL Evo D Vs lightweight urgestalt
AJ1980
13
1668
Sat Jan 07, 2017 10:50 am
kgt View the latest post
There are no new unread posts for this topic. Brakes
goldielox
10
881
Sat May 14, 2016 7:11 am
Synnove View the latest post
Users browsing this forum: Arjan, chazmtb, Devotional, Grill, kgt, NYCPrynne, Yahoo [Bot] and 23 guests
