It is currently Fri Jan 19, 2018 10:56 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Apr 17, 2013 6:33 pm
I have a Time carbon stem. The other day when I was tightening the one of the screws that adjusts tension on the fork, the screw broke in half Time is not a US company, and the stem is at least 3-4 years old. I'm not to sure what do, since it looks like a pretty unusual screw. Any thoughts?
This is the stem I have:
http://www.ebay.com/itm/Time-Monolink-C ... 0639935485
PostPosted: Wed Apr 17, 2013 6:39 pm
if you can't tease it out, use a screw extractor to remove the broken bit
take out the good bolt, check it, measure it, it'll probably be m5, order a couple of new ones - it's a stem bolt, i'd go for high tensile steel just for margin, but standard will probably be ok too
PostPosted: Wed Apr 17, 2013 7:28 pm
I had already got it out. Where can I order these?
PostPosted: Wed Apr 17, 2013 7:50 pm
Pretty much anywhere, I usually use Toronto Cycles for no particular reason. Just make sure to measure the width and length.
PostPosted: Wed Apr 17, 2013 10:01 pm
PostPosted: Thu Apr 18, 2013 12:36 am
What's nonstandard about them? Looks exactly like a narrow head M5.
If you really want to know, take the stem down to your local hardware store and try a couple of different bolts. Or your LBS and ask them to try an M5 in it.
PostPosted: Thu Apr 18, 2013 5:23 am
TIME don't make screws, they got it from a screws manufacturer. So you still can find it in this world. If not Pls help to SCREW them for making life challenging for us.
PostPosted: Thu Apr 18, 2013 10:08 am
I would check the stem and fork, you probably overtightened the screw
PostPosted: Thu Apr 18, 2013 1:47 pm
There are no new unread posts for this topic. THM Fibula just broke.
KCookie
Tue Jan 16, 2018 1:45 am
jimaizumi View the latest post
There are no new unread posts for this topic. Canyon H31 mount screw
Kristian78
Sun Sep 10, 2017 7:59 am
MayhemSWE View the latest post
There are no new unread posts for this topic. Where can I find a deda adjustment screw
dwn2sk8
Mon Apr 03, 2017 1:26 am
dwn2sk8 View the latest post
There are no new unread posts for this topic. Ultegra 6800 Reach Lever Screw broken
probertsqbe
Tue Feb 14, 2017 12:09 pm
probertsqbe View the latest post
There are no new unread posts for this topic. Picked up a screw... fork scratched - nail polish, or paint?
mike001100
Sun Dec 17, 2017 7:54 pm
antonioiglesius View the latest post
Users browsing this forum: beeatnik, CarlosFerreiro, Miller, Monkeyfudger and 33 guests
