Garmin Out-in-front Mounts Ad Nauseum
sigismond0
by sigismond0
I get 9mm c-c and 14mm outside. Are you measuring the center of the holes or the outsides?
To make sure we're talking about the same thing, I have this exact stem:
Edit: This was the the person two posts up, not the one directly above me.
For the one directly above, looks like we're within .5mm of each other. To get an exact measurement (that doesn't involve eyballing the centers), unscrew the bolts slightly and measure the outside of the bolt shafts. It should be around 14mm. Then measure the diameter of one bolt, which should be somewhere around 5mm. Subtract for an exact measurement. (Looks like we're measuring the same stem, but your calipers are better than mine, but you're eyeballing where the centers are.)
Lewis
by Lewis
Ah my stem is different although it does say 4 axis on it.....will post a photo tomorrow.
2012 Canyon Ultimate AL 8.0
Vuong05
by Vuong05
Can anyone recommend me a mount that can be mounted to a handlebar with sweep back? I have a MCFK road handlebar that has a sweep back of 5 degrees.
Lewis
by Lewis
sigismond0 wrote:I get 9mm c-c and 14mm outside. Are you measuring the center of the holes or the outsides?
This is the stem I have - this isn't my exact stem but mine is the same as the one on this Canyon. If required I can post a photo of my exct stem with calipers measuring the space between bolts. Please let me know, thanks.
sigismond0
by sigismond0
Yeah, looks like you have the 4-Axis 44, which has a wider faceplate.
xclemjustinx
by xclemjustinx
k-edge mounts, nuff said
Support American made
Lewis
by Lewis
Screw that, I'd rather something European made not something from the gas guzzling u s of a! :P
Jokes aside, I do prefer tillquists mount to the k edge.
nathanong87
Resident master of GIF
by nathanong87
bought a tate labs 2.0 barfly. really sick piece. my only grip is that the bottom part of it is super bulky and interferes with right side cables. Doesn't cause binding and still aligns straight, it's just weird. But SUPER SOLID feeling. The click to engage the edge 500 is like massively sturdy.
Stoo
by Stoo
I've also fitted a BarFly V2.0 this evening.
As above, interferes with cables ever so slightly, but puts the computer in a much better position IMHO.
CLICK
'17 Giant Trinity Pro TT - DA9070 - Rotor 3D+ P2Max - Zipp 900T/HED Jet 9+
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'15 Cannondale Super Six Evo HM - DA9000- DA9000 SRM - CC40C
'13 Giant Trinity Composite - U6800 - QuarQ DZero
Getter
by Getter
shinobiph wrote:http://www.bikeradar.com/news/article/tate-labs-bar-fly-mtb-garmin-mount-to-be-offered-37625/" onclick="window.open(this.href);return false;
Nice!
I like my Garmin on my stem for my mountain bike...but using a 70mm stem...its too short to run the stock Garmin mount. I wonder if the new Bar Fly would allow me to center my 510 on the 70mm stem.
This is what I currently use:
I would like to have the Garmin centered on the stem.
BeeSeeBee
by BeeSeeBee
carbonLORD
by carbonLORD
But I moved to Europe :wink:
Honestly, I like the Garmin. It is matte black and matches the bike I use it on and I like that the clamp is lined in rubber so it wont slip and gouge up a set of $350 handlebars. Plus, I own a Garmin.
Tillquists mount looks nice, but he is clearly more into posting pics and blogs then making it for anyone.
K-Edge, alloy.... skip.
Some of the self-made offerings are nice but look like everyone else so whats the point?
I'll save more weight with a skewer or lighter tires/inner tubes (where grams matter).... I know, I know, this is WW (go drill some holes in your Garmin mount)
I'm waiting for a mahogany or bamboo one :idea: (not rly)
carbonLORD.com
by 573
carbonLORD wrote:Tillquists mount looks nice, but he is clearly more into posting pics and blogs then making it for anyone.
Yep, I've pretty much given up trying to find out when or if I can buy one.
grymg
by grymg
I recently picked up the SRAM QuickView because it was only $16.45 shipped on Amazon and tried it for the first time today. I think at that price I'm going to equip all of my bikes with it. It's 19g, subtract out the original 8g of the stock Garmin band mount and it adds 11g to my steed. . . It's molded plastic with hollow recesses underneath so I don't think you can get much weight out other than the bolt. To mount it I had to spread open the c clamp pretty wide but fortunately it didn't break. Bolt was torx which was annoying. . . but after using carbon paste and tightening it 1/4 past finger tight, it's not moving anytime soon.
Bonus was due to how thin the clamp was, it fit perfectly in between the two zipties on my Di2 satellite shifter.
I was weary of the aesthetics with it on because I like the handlebars with a clean front end, but I guess it will grow on me. Hey, now I can actually see the 3T logo on my stem :mrgreen: (that reminds me - I should scratch out the SRAM logo on this) The head unit fits snug and is harder to lock in, better than the stock mount so it's not going to accidentally rotate out. I don't have to look as far down to see the display which is the main reason I got this so the weight gain is worth it.
With safety in mind I hope more companies come out with the sunglasses mounted head units so I wouldn't even have to look down. If it was in the $300 range I wouldn't hesitate. For $499 or $599 whatever it is now, I'll pass.
On a related note I was tired of being buzzed by stupid drivers all the time so I also got a cycling mirror (Bike Peddler Take a Look) and it is lifechanging. I may look like an old geezer but I don't have to turn my head to see behind me which keeps my head straight as it should be.
