It is currently Tue Jan 23, 2018 3:24 pm
Post new topic  Reply to topic  [ 415 posts ]  Go to page Previous 13 4 5 6 728 Next
PostPosted: Thu Apr 25, 2013 11:53 am
So beautiful that I bought a new Garmin [does not work with 705] and stem [does not work with a Ritchey WCS]. It is a work of art and would do it again.
PostPosted: Thu Apr 25, 2013 2:19 pm
Totally agree it was one of the reasons I got the 3T setup and its a perfect match for the 3T stealth Team color (or lack of color)
PostPosted: Thu Apr 25, 2013 2:47 pm
Can someone get dimensions on the width of the handlebar clamps of the various units? I've got vukasprint bars and don't have much clamping area at all.
My Giant TCR Advanced SL 2014
My Specialized Venge 2013
My Scott Plasma 2
PostPosted: Thu Apr 25, 2013 4:35 pm
Most are around .5 of an inch, I believe. If you need a really narrow clamp, K-Edge will likely be your best bet. It's .25ish of an inch.
PostPosted: Thu Apr 25, 2013 5:20 pm
Standard Garmin mount with rubber bands is 8 grams. That works fine for my Edge 500, but I've had to send back three separate Edge 500s because of plastic tabs breaking on me (just dropped #3 in the mail this morning). The display of the Edge 800 is difficult to see unless the angle is perfect. Stem-mounting thus doesn't work well. I am definitely interested in a forward mount for that. Tillquist's excellent mount will put the computer at the stem angle. That's okay for a flat stem, but for a flipped one, it may be an issue. Mountain the unit further ahead, alone, may help visibility, however, by shifting the viewing angle.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Apr 25, 2013 11:53 pm
The SRAM Quickview clamp is 9mm (just over a third of an inch)
PostPosted: Sun May 12, 2013 5:25 pm
I should have given some thought into the vuka sprint mount area - bought the raceware mount and apparently it is a newer version with a mounting clamp a full 15mm wide. Good news for WW though, it's 12g on the dot. Oh well, I am trying to see if I can get it exchanged with someone else on the local forum now...
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Mon May 13, 2013 12:35 am
I fit the SRAM out front mount on my Vukasprint without issue. That's about the widest mount you'll fit though.
I've changed bars now though. Happy to swap mounts with anyone in a pickle :)
Current:
T2
Retired:
PostPosted: Mon May 13, 2013 6:46 am
I have the design cycle with version for the edge 500. Works fine and looks good BUT, it seems like it chewed the plastic tabs that hold the garmin in the mount. On a descent my edge went flying. I found it and exchanged it. I recently received a new design cycle mount that holds the 500 and the 800 and it is extremely tight to get the edge 500 in there. I am concerned that it can break the tabs again..
PostPosted: Mon May 13, 2013 7:30 am
You need this one for the Zipp Service Course SL stem
See all my bike h e r e
PostPosted: Mon May 13, 2013 2:15 pm
Garmin Outfront works perfectly for me. Very secure mounting ... more so than the standard Garmin mount.
I'm not one of those people who breaks things, so your experience may vary.
PostPosted: Mon May 13, 2013 2:45 pm
This is exactly what I did :wink:
My Scott Plasma 2
PostPosted: Mon May 13, 2013 3:10 pm
Morten, I only held off on ordering one because I was unsure if I'd keep the combo. I'm glad I didn't pull the trigger because alas, I sold the Zipp stuff.
Now I need one for 3T :)
Current:
T2
Retired:
PostPosted: Mon May 13, 2013 10:01 pm
3T is sold out
PostPosted: Sat May 25, 2013 7:40 am
Looking for a Garmin mount that puts the unit in front of the stem. I just picked up a MCFK road handlebar that has a -5 degree sweep back.
Any recommendation would be appreciated.
There are no new unread posts for this topic. Garmin out front position
hlvd
20
1515
Wed Sep 13, 2017 10:51 am
Juanmoretime View the latest post
There are no new unread posts for this topic. Out-Front Mount Request - to hold a Garmin 500 & Bontrager Ion 700
Matt28NJ
Thu Jan 26, 2017 3:56 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Inside bike storage mounts
gerryc89
Fri Jul 28, 2017 10:09 am
Lelandjt View the latest post
There are no new unread posts for this topic. Single Speed Frame & Fork with Mudgaurd Mounts
SgtRock
Wed Jun 14, 2017 3:37 pm
Ulver View the latest post
There are no new unread posts for this topic. Garmin Edge 520
in Wanted
vladoo
Tue Dec 26, 2017 12:39 pm
vladoo View the latest post
Users browsing this forum: No registered users and 9 guests
