Vittoria Open Pavè 27mm
HillRPete
by HillRPete
Got myself a pair of 27mm Pavè clinchers, now wondering which (butyl) tubes would go with them. I'm a Conti guy, but their road tubes only go to 25mm per spec, their tour line starts at 28mm. Got spare supersonic tubes also, too risky?
They will be used in bad weather a lot, so I'll probably better be safe than sorry. Not looking forward to fixing flats in the pouring rain.
SalsaLover
by SalsaLover
Michelin Latex works for me
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
Stolichnaya
by Stolichnaya
Vittoria makes a tube in both latex and butyl called the Ultralite that runs from 25mm to 28mm.
The weight was also completitive as I recall.
em3
by em3
SalsaLover wrote:Michelin Latex works for me
+1....Been using Michelin latex on Paves for a long time....better flat protection with latex and sublime ride. EM3
______________
MattSoutherden
by MattSoutherden
Ditto.
Michelin latex may not be the lightest, or most supple, but they seem more robust. I'm running them with 24mm Pavé
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
Devon
by Devon
Put the 28 Conti in. Slightly higher puncture resistance that way. I run 25 tubes in 23 tyres.
Campagnolo; because it's a bicycle, not a fishing rod.
teleguy57
by teleguy57
+1 on the Michelin latex. Only flat I ever had in my Open Pave CG 24s was due to user error in mounting. Amazing ride -- I believe the latex actually is more puncture resistant.
HillRPete
by HillRPete
Mounted them today, with the 28mm Conti tubes. They measure a hair under 27mm on Open Pro rims when inflated (Exactly the same width as the 28mm spec'd Conti GP 4 Seasons). Looking forward to ride them.
LouisN
by LouisN
I tried Vittoria latex 18/23mm and Michelin aircomp latex 22/23mm on my Challenge Parigi-Roubaix 27 mm.
The Michelin is holding up fine. The Vittoria lasted one ride, ripped around the valve mount.
Louis :)
Youcef
by Youcef
You use carbon rims?
You use latex tubes?
You be careful on large descents!
The latex can adhere to the rim insides with the heat build up and actually pop.
russianbear
by russianbear
This is sort of unrelated, but can you measure their actual width when mounted and pumped up? I'm wondering if they will clear my scott cr1 (pre addict) frame.
I wouldn't worry too much about matching the tubes up exactly. You can go a size smaller without consequences I think.
HillRPete
by HillRPete
Russian: just under 27mm on Open Pro rims (3 posts up).
indigo
by indigo
Is OP not specifically asking for butyl tubs ??
xjbaylor
by xjbaylor
Correct. In a pinch I ran 19/23 tubes in a 35mm CX tire with no issues. Running 25's in a 28 seems like it would be the WW norm!
russianbear
by russianbear
wassertreter wrote:Russian: just under 27mm on Open Pro rims (3 posts up).
Oh jeez how did I miss that that! Thanks.
