It is currently Sun Oct 22, 2017 6:43 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject: Re: last tubular flat?
PostPosted: Mon Apr 15, 2013 5:52 am
RyanH wrote:
I've done about 6k miles on Conti Sprinters in Urban LA with two flats. One was in the rain where 12 out of 16 of us flatted. Vittoria Pit Stop worked on that flat. The last time I flatted was due to the valve completely failing. I had to put on my spare tub, which took less time than my friend's flat repair on his clinchers (we flatted at the same time).
On clinchers, I used to suffer a decent amount of pinch flats due to the numerous pot holes we have over here.
you must have very strong fingers....or know of some tricks to get that tubi off the wheel ??
PostPosted: Mon Apr 15, 2013 6:13 am
I have two bikes that have Veloflex Arenberg on them, one bike got a rear flat in 90 miles, the other I replaced the tire with no flats after 2641 miles! Both are always ridden throughout the same routes, what gives :)
PostPosted: Mon Apr 15, 2013 6:44 am
Stay away from shitty $30 tubs. Because I was too impatient to wait for my vittorias to come in from the UK, I bought a pair of continental giros. Two flats in under 25mi worth of riding. Both straight through the center of the tread from normal road debris, no nails, screws, or thin bits of wire.
PostPosted: Mon Apr 15, 2013 8:57 am
I use tire levers it help a lot.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
PostPosted: Mon Apr 15, 2013 1:31 pm
SpinnerTim, Great writeup
Because you run lower air pressure that can help reduce the chances of some flats. Your tire will flex more easily and you will be able to run over a sharp object without it cutting into the tire.
PostPosted: Mon Apr 15, 2013 3:45 pm
Last one was last September - sharp rock gash/puncture on a large-aggregate gravel road (Todd Road North, Katonah, NY). Continental Competition 22mm. It is stupid to ride 22mm tubulars on gravel, but sometimes, it's fun to be stupid.
There are no new unread posts for this topic. Compact Handlebar with Flat Top?
daveydoo
24
1836
Thu Aug 17, 2017 2:47 pm
daveydoo View the latest post
There are no new unread posts for this topic. Attachment(s) Flat brazeon tab, what to do (Simplon frame)
Alexandrumarian
Sat Sep 09, 2017 2:34 am
bikerjulio View the latest post
There are no new unread posts for this topic. Cannondale SI non-flat Crank-Spider interface
Kurets
Sun Apr 16, 2017 9:03 pm
Kurets View the latest post
There are no new unread posts for this topic. Reynolds 81 Tubular vs FSE EVO 79T Tubular , help!
xpert
Sun Jan 08, 2017 5:51 pm
xpert View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
Users browsing this forum: mrtkcmz and 46 guests
