It is currently Mon Feb 27, 2017 6:12 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Apr 12, 2013 11:37 pm
Anybody have experience with using an aftermarket chainring with shimano as I would like to know what brand, if any, 36 tooth chain ring is compatible with shimano 7900 crank? Thinking about upgrading to 9000 36/52 crankset but would like to demo the 36 on my bike first.
PostPosted: Sat Apr 13, 2013 12:25 am
I have had the Praxis 52/36 rings mounted on 7950 crankarms...these are 110 BCD and don't work on 7900 arms (130 bcd)
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
PostPosted: Sat Apr 13, 2013 12:41 am
a 38T is technically the smallest you can engineer on a 130BCD. Any smaller the CR bolt is directly in the tooth bed.
Adam@Praxis
Praxis Works
Manufacturer
Santa Cruz, CA
www.praxis-works.com
PostPosted: Sat Apr 13, 2013 3:39 am
My bad I meant the 7950.
PostPosted: Sat Apr 13, 2013 8:39 am
I own shimano's 36t. (110) from their CX cranks (fc-cx70).
Works a treat, but might be heavier than DA (but quite impossible to find though).
There are no new unread posts for this topic. SRAM RED GCP Cranks & Chain Ring WEight
RezaTrek2200
12
858
Sun Dec 04, 2016 10:28 am
mythical View the latest post
There are no new unread posts for this topic. Quick link? (on a shimano chain.)
eaglejackson
11
813
Fri Jun 17, 2016 7:43 am
sungod View the latest post
There are no new unread posts for this topic. Can I add a new 9150 Di2 Battery with blue tooth to my 9070
mnmasotto
9
465
Mon Feb 20, 2017 10:47 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
19
1125
Sun Feb 19, 2017 7:54 am
Delorre View the latest post
There are no new unread posts for this topic. Standard chain rings to semi compact chain rings = new crank?
stockae92
11
679
Fri Sep 23, 2016 8:27 pm
topflightpro View the latest post
Users browsing this forum: Bing [Bot], madonna, mcgheew, rcb78, samuel86, Yahoo [Bot] and 35 guests
