It is currently Tue Jan 23, 2018 1:28 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Apr 10, 2013 8:31 pm
Maybe I am missing something obvious, but here is a pic of the inside of my Veloflex Corsa.
Planet-X Nanolight HM - 5.63kg
PostPosted: Wed Apr 10, 2013 8:38 pm
Some companies by products from another and rebrand them. Others have products manufactured by other companies for them.
PostPosted: Wed Apr 10, 2013 8:55 pm
I know that much, but I didn't know about a Veloflex-Schwalbe cooperation. They still have made in Italy on them.
PostPosted: Thu Apr 11, 2013 12:31 am
Tubbie Guru
Hi,
What doe the outside say?
Ciao, ;)
PostPosted: Thu Apr 11, 2013 1:26 am
No doubt. Those are not Schwalbes. The folded over "open tubular" design does not fit Schwalbes MO. Plus, last time I checked, Schwalbe didn't use cotton casings.
PostPosted: Thu Apr 11, 2013 2:16 am
That exact text is written on Schwalbe Inner tubes, though. Some kind of transfer effect?
PostPosted: Thu Apr 11, 2013 2:26 am
Mr. Muncher might be on to something. 18-28 isn't exactly a common tire size. :D
PostPosted: Thu Apr 11, 2013 2:35 am
Haha! Think we have solved the mystery....
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Apr 11, 2013 4:35 am
Only used them with vredenstein latex tubes.. Maybe the shop have mounted them before? But I remember they arrived sealed in the box. The transfer makes a lot of sense though.
PostPosted: Thu Apr 11, 2013 4:52 am
but if it were a transfer from a tube, would it not be mirrored?
PostPosted: Thu Apr 11, 2013 5:47 am
Indeed , it'd be mirrored
Pro-Lite Cuneo
PostPosted: Thu Apr 11, 2013 7:54 am
15 is the number for their racing innertube,
Indeed, it should be mirrored.
Maybe Schwalbe and Veloflex are made in the same factory?
PostPosted: Thu Apr 11, 2013 8:07 am
Last time I checked open tubular = clincher with added marketing.
PostPosted: Thu Apr 11, 2013 9:09 am
Right it suddenly all makes sense, sorry for the fuss :oops:
I mirrored the pic before I upload it just to be easier for reading. And I remember I got a flat while I was my way to the tourmalet and bought a schwalbe tube of a local shop. It was a very hot day (probably around 35+) so I assume in the descent the wheels got hot and thats how the mark got there.
Now I probably need to go to a doctor and check the memory gaps :oops:
PostPosted: Thu Apr 11, 2013 9:54 am
An open tubular as apposed to a clincher would be a tire with a high thread count cotton casing, with a glued on tread (so as not to effect the casing's feel) that would normally be sewn into a tubular. that has instead had it's edges folded around a bead to be used on clincher wheels. Clinchers tend to be lower thread count, nylon cased tires that have everything vulcanized together. And the two ride very differently.
There are no new unread posts for this topic. Parlee serial numbers inside BB?
paregreen23
Thu Sep 28, 2017 6:18 pm
parlee_Z1 View the latest post
There are no new unread posts for this topic. Schwalbe One tire weights?
2lo8
Sun Jun 25, 2017 12:28 am
gewichtweenie View the latest post
There are no new unread posts for this topic. Schwalbe One Tubular- Max Loading
lord_brush
Fri Mar 03, 2017 10:18 am
lord_brush View the latest post
There are no new unread posts for this topic. Which veloflex tubular for HED Stingers?
SpecializedColnago
Tue Jun 13, 2017 1:54 pm
Geoff View the latest post
There are no new unread posts for this topic. Attachment(s) Veloflex / Open Tubular max internal rim width safety
possibleweenie
20
1102
Tue Aug 29, 2017 11:21 pm
mpulsiv View the latest post
Users browsing this forum: Hexsense, joe1234, Majestic-12 [Bot], mogwaiboi, sovereign and 38 guests
