It is currently Tue Jan 16, 2018 9:00 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Wed Apr 10, 2013 8:11 am
I've only used shimano to date.
Can anyone educate me as to the compatibility of Sram components between 2012/2013 and/or force & red?
my main goal is to take some weight off the bike (while keeping the costs down).
looking at my options in terms of a mix of 2013 red & force -or- a mix of 2012 & 2013 red i think.
will prob. wind up keeping the existing q-rings and cnc brakes.
thanks in advance!
PostPosted: Wed Apr 10, 2013 9:13 am
Oficial SRAM statement here: http://issuu.com/sram/docs/sramred2012_en?mode=window (page 42)
WW feedback here: http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=111380
Good review here: http://velonews.competitor.com/2012/03/news/it-works-we-test-sram-red-backwards-compatibility_209270
More here: http://forums.roadbikereview.com/components-wrenching/sram-red-2012-2013-backward-comaptable-278410.html
My compatibility experience was moving from Force to Red 2012 over a 6 month period.
  • new cassette needed (wear and tear), replaced with XG-1090. Result was quieter and better shifting
  • 2 months later swapped out Force FD and crankset for Red 2012 FD and crankset. Result was better front shifting (using Force shifters)
  • 2 month swapped out Force RD for Red 2012 RD. No significant change (using Force shifters)
  • 2 months later swapped out Force shifters for Red 2012 shifters (could not resist a heavy discount)
PostPosted: Wed Apr 10, 2013 3:25 pm
The only thing I wouldn't do is use the new front shifter with a non-yaw front derailleur. You'll lose trim. You can use the yaw FD with the old trim shifters though.
Other than that, every single Sram road component is intercangeable.
PostPosted: Wed Apr 10, 2013 8:36 pm
I have posted about this before.
basically, SRAM FORCE/RED are completely intercompatable, in spite of what the official position is.
You may get the advantages of the RED shifters or less reason to need to trim with the YAW shifter, but they all work together at least as well as they ever really initially worked. Not much difference even with the alleged advantages of the newer/higher end versions.
PostPosted: Wed Apr 10, 2013 8:40 pm
If you use the current red shifter with a non-yaw derailleur, you will run into more chain rub problems than any correct match or using a trim shifter/yaw derailleur. It will pull the derailleur just fine, but it won't rotate it and you won't have any trim positions. Other than that, you are correct.
PostPosted: Thu Apr 11, 2013 8:13 am
I tried this and whilst the Yaw FD works with the 2012 levers it's not great. When i finally got my hands on the 2013 levers the difference was big. Much cleaner shifting and lighter to the touch.
Unfortunately the 2013 group works best with the whole group.
Hope this helps.
PostPosted: Thu Aug 29, 2013 12:59 am
Anyone use a Force 22 FD with the 10 speed stuff?
79g vs 76g for the 2012 Red yaw FD (claimed), and half the price.
PostPosted: Thu Aug 29, 2013 2:55 am
Yaw 22 FD's are narrower than 10spd. You'll likely have trouble setting it up without chain rub on a 10 speed system.
PostPosted: Thu Aug 29, 2013 3:50 am
Is that something you've tried, or just hearsay?
Seems illogical given that the chain width difference is only 0.33mm, and the 11-spd cassette is 1.85mm wider. So the 11-speed setup should be able to handle MORE misalignment than the 10-speed.
PostPosted: Thu Aug 29, 2013 2:16 pm
No, the Force 22 FD will give you chain rub on a 10s setup. It will likely give you slightly worse shifting as well.
This is assuming you're using it with regular 10s rings. If you use the Force 22 FD with the Force 22 rings, you'll probably get away with little to no chain rub. Yaw rings are spaced ever so slightly wider than regular rings, which means shifting isn't 100% perfect when using a yaw FD on older rings. It's still functional, just not as good as a matched front set.
PostPosted: Thu Aug 29, 2013 2:54 pm
^^ Hey, you bought my Cannondale Red crank. Small world. :P
I'll probably be running Praxis rings, so I guess I'll pony up for the Red 10-speed yaw. Thanks for the help.
PostPosted: Thu Aug 29, 2013 3:12 pm
Awesome! I'm planning on getting the 10s Yaw derailleur and the 10s Red rings to put on those cranks!
I originally had 10s Force cranks/deraiileur and tried to use Force 22 rings. Long story short, it didn't even remotely work and I got sad. On the plus side, the Force 22 rings are the ugliest, bluest grey ever so I got to sell them and never have to look at them again...
Right now, my goal is to put Yaw on the front, and then modify my front shifter so that it loses the trim position. Running Yaw with old shifters works fine, but makes that trim stop completely pointless.
PostPosted: Thu Oct 03, 2013 5:32 am
Okay, one last question.
Can I use a 10-spd (Red 2013) Aero Glide rear derailleur on the 22 setup?
PostPosted: Thu Oct 03, 2013 6:26 pm
It shifts...but the low limit trim screw ends up backed way out, which looks a bit goofy... I stuck my 11s rear wheel on briefly to check proof of concept, but didn't dial the adjustments all the way in. Might be able to cut down the low limit trim screw / order a different part.
I should play with it a bit more to get it make sure it works perfectly, but I'm short an 11s wheel on the bike with the 2013 aeroglide derailleur, and have events the next 3 weekends, leaving me short of time to experiment.
I can confirm that the shifting works well on the 10s wheel with the 16t cog removed from the pg-1070 using sram red 22 shifters, and the older aeroglide derailleur. (The 15-17 shift is a bit off at times, but that's to be expected)
I'll also state that I like the shape of the ergodynamic hoods over the previous generation, especially when out of the saddle climbing.
PostPosted: Thu Jan 23, 2014 2:11 pm
Could anyone tell me if Sram Red shifters (10 speed, 2013) are compatible with Sram Force (non 22, 2012) derailleurs?
I read somewhere that there would be a problem with the new 'yaw' system.
Any help would be appreciated! :beerchug:
There are no new unread posts for this topic. Sram Red BB386 crank arm compatibility
Jian81
Sun Dec 17, 2017 2:00 am
Jian81 View the latest post
There are no new unread posts for this topic. SRAM Red chainring compatibility with Shimano 9150 Di2
bpe
Sat Jul 08, 2017 4:53 am
pdlpsher1 View the latest post
There are no new unread posts for this topic. Help with Sram Red/Force RD
Hardstyle
Mon Jul 10, 2017 12:04 am
Hardstyle View the latest post
There are no new unread posts for this topic. Quarq DZero Spider Sram Rotor compatibility
Jian81
Sun Dec 17, 2017 7:02 am
dre_lo82 View the latest post
There are no new unread posts for this topic. SRAM Force 22 vs Red 22 shifters
loudtiger
10
988
Mon Aug 14, 2017 4:07 pm
youngs_modulus View the latest post
Users browsing this forum: darnellrm, Google Adsense [Bot], Madone69, Malammik, markyboy, parlee_Z1, raggi and 39 guests
cron
