It is currently Wed Oct 18, 2017 9:46 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Tue Apr 09, 2013 9:07 pm
I have received my wheels from built. Built on Tune Mag/Mig 170/70 tubless rims Stan's 340 mode year is 2013 24/28 CX Ray spokes. As I mentioned 11speed freehub body. I haven't receive with it the spacer (1.8mm) in order to use my 10 speed cassette Dura Ace 28/11. Never the less I installed the 10 speed DA cassette with the 1mm spacer it comes with and there is no freedom at all but the ride is "heavy" feeling, it seems like it is very difficult to accelerate with the wheelset. I can compare it to my Zipp 404 tubular wheelset I have (almost the same weight with my current wheels around the 1300 gram for pair) but so much different...! I'm waiting for the 1.8mm spacer to arrive but I wonder if the lack of this spacer can be the cause of this "heavy" acceleration feeling or it has nothing to do with it and it is most probably the wheels alone. Ill love to hear your take on that.
PostPosted: Tue Apr 09, 2013 9:19 pm
I don't see how having too few spacers would make it feel that way. Too many spacers could do that, causing everything to be compressed together too hard and bind up, but too few spacers should only cause the cassette to slide around and mis-shift.
Another thing to consider is your tires/tubes. What do you have on each of the wheelsets?
PostPosted: Tue Apr 09, 2013 9:26 pm
On the new build I have tubeless Hutchinson Fusion 3 on the Zipp I have Conti Sprinter Gatorskin tubulars
PostPosted: Wed Apr 10, 2013 11:52 am
I've ridden a few sets of Hutchinsons.......they felt pretty awful but that was many many years ago....surely they got better??
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Wed Apr 10, 2013 1:21 pm
Doubt it's a spacer issue. Do both wheels spin freely when mounted in the frame?
If they do, I'd be inclined to swap out the Fusions for a borrowed pair of Conti GP4s clinchers (& tubes) just to see how that felt in comparison.
PostPosted: Wed Apr 10, 2013 3:03 pm
Those Fusion 3's are heavy. I had the Intensives ("25mm") previously, and was unimpressed with their ride quality. Although the Fusions are lighter, it isn't by much. I would recommend running the Atoms, or swapping over to another manufacturer's offerings. I've read that the Bontrager R3 Tubeless tires are good (the R2's are not as good, from what I have heard).
Madone 4, SpeedConcept, Cobia. I own a lot of Treks.
PostPosted: Wed Apr 10, 2013 7:37 pm
+1 the Bonty R3s are lighter than the Hutchinsons, and perform well.
Clinchers are (pretty much) always going to have a heavier rim than tubs, for obvious reasons.
PostPosted: Thu Apr 11, 2013 8:44 pm
Thanks for all your comments. I have add the 1mm spacer while I am waiting for the 1.85mm to arrive. I can't say it's the spacer because it can be many other things but I have rode the bike again with the 1mm spacer and I adjust the pressure in the Fusion for 80 front and 90 rear and the ride was good, the feeling was nice, the speed and acceleration was what expected even though it wasn't my hilly route. Ill keep to update soon
Thanks!
PostPosted: Thu Apr 11, 2013 11:44 pm
Not sure if you are aware but you need to use both 1.85mm and 1mm spacers when running a 10speed casette on 11speed DA wheels.
PostPosted: Fri Apr 12, 2013 12:01 am
Dha
Yes of course beside the 1mm that comes in between the block I use meanwhile another 1mm instead of the 1.85
Thank you
PostPosted: Fri Apr 12, 2013 9:31 am
Yes that is correct. Shifting is ok without both spacers but not perfect.
There are no new unread posts for this topic. Attachment(s) SRAM or Shimano 11 speed cassette
DeLuz
33
2442
Wed May 03, 2017 12:59 pm
muntos View the latest post
There are no new unread posts for this topic. Campag 10 speed cassette with 11 speed chain?
campagowlo
Sun Apr 16, 2017 1:10 am
BRM View the latest post
There are no new unread posts for this topic. Shimano Dura Ace 9000 free hub body backward compatibility?
BeeBee30
Wed May 17, 2017 7:32 am
petal666 View the latest post
There are no new unread posts for this topic. Shimano cassette body for Mavic R-SYS SLR 2015 wheel
Tillquist
Tue Jun 27, 2017 6:26 am
Tillquist View the latest post
There are no new unread posts for this topic. Attachment(s) Adding 16T to 11-xx 11 speed cassette
efeballi
12
816
Sat Oct 07, 2017 10:10 pm
efeballi View the latest post
Users browsing this forum: Bing [Bot], cveks, Google Adsense [Bot], ironhayden08, the jackel, TobinHatesYou and 43 guests
