It is currently Tue Jan 23, 2018 5:28 am
 Post subject: bb30 play
PostPosted: Tue Apr 09, 2013 6:26 pm
hi all,
cleaned the bike today and realised the bb30 bottom bracket on my caad10 has developed some play. By this I mean by holding one crank arm I can slide the entire bottom bracket roughly 1mm in and out of the bb shell.
Now only 2 weeks ago my mechanic at the lbs replaced the bearings and regreased everything in there and since then I have only ridden this bike twice. My thinking is that he didn't install the bottom bracket correctly and over these 2 rides its simply loosened up?
I consider myself pretty good at servicing everything else on the bike just don't have the funds (student) to invest in tools to checkout the bb.
What are your thoughts?
 Post subject: Re: bb30 play
PostPosted: Tue Apr 09, 2013 6:50 pm
sounds like incorrect install
generically it could be...
- preload adjuster hasn't been set (if it has one, some just have a stack of washers in which maybe they're missing)
- spacers or bearing covers are missing
- the two parts of the crankset haven't been fully scrunched together by the locking bolt
PostPosted: Wed Apr 10, 2013 4:59 am
edited
PostPosted: Wed Apr 10, 2013 6:38 pm
This is a picky point but wave washers should be complety compressed. If you do that you are putting un do sideload on the bearing. You might as well just use a shim thats the same thickness as the wave washer. Just make sure that the wavewasher is lightly compressed.
I deally, if you like to tinker and have very thin shims, you would not use a wave washer and just use shims that allow no slop but just barely sideload the bearing.
PostPosted: Wed Apr 10, 2013 7:32 pm
{USERNAME} wrote:
This is a picky point but wave washers should NOT be completely compressed.
That's what you meant to say, right?
From Cannondale:
{USERNAME} wrote:
Apply bearing grease to the crankarm BB spline hole, spindle end
and the thin washer and fixing bolt threads. Tighten-non drive the
fixing bolt to 40 Nm, (30 FtLbs) and check to see if wave washer
is properly preloaded (still has slight wave and not loose). If it is
loose, remove the crankarm and add another shim. Up to 3 shims
can be used. Add shims as needed.
There's sometimes a buggy.
One.
PostPosted: Wed Apr 10, 2013 8:32 pm
BB30 design is a sore point for me too.
Notice that SRAM has gone back to an adjuster that takes out all the play without a wave washer.
I believe the wave washer is a bad design. You should use shims that take up all the space, but do not put a significant sideload on the bearings.
I had a lot of creaking and clicking problems until I used some feeler gages to add just enough shims to where the wave washer is just crushed flat, but no further. That seems to work for me.
PostPosted: Wed Apr 10, 2013 11:08 pm
Yet another reason threaded bottom brackets rule!
If it ain't broke don't fix it.
PostPosted: Thu Apr 11, 2013 1:29 am
Best way to adjust preload on a wave washer system:
First install everything with no additional preload spacers. Check the amount of space is in the "wave" part of the wave washer. Physically slip a number of preload spacers in that gap, the number of spacers that EASILY fits is the number you use. It is allowed to compress the wave washer all it wants as long as it does not bottom out. A tiny gap is still a gap.
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. Play in Extralite UltraFront SX hub and bearing size
sanrensho
Tue Jun 06, 2017 5:15 pm
sanrensho View the latest post
There are no new unread posts for this topic. BB30 : Sram + fsa compatibilty?
alcatraz
Fri Jul 28, 2017 3:18 am
CycloTron View the latest post
There are no new unread posts for this topic. Cannondale bb30 opinions
Jcgill
Tue Apr 18, 2017 6:54 am
slick1 View the latest post
There are no new unread posts for this topic. Investing in BB30 PM a bad idea?
AW84
33
2909
Mon Aug 21, 2017 9:31 pm
bm0p700f View the latest post
Users browsing this forum: Bing [Bot], dcpdpayne, Google [Bot], Wookski and 32 guests
