It is currently Thu Jan 18, 2018 9:31 am
Post new topic  Reply to topic  [ 105 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Sat Apr 06, 2013 3:32 pm
Bicycle Quarterly, Spring 2013 issue, has an interesting selection of rolling resistance test data. I recommend buying this if you can find it. I subscribe to the magazine and read every article: I really enjoy it even though it's focused more on randonneuring than on racing bikes. You don't need to agree with everything written in a publication to enjoy the discussion if there's interesting data, as we know from Tour magazine's frame tests.
They ride a track with a Powertap, possibly with an SRM as well (in most recent tests), at a moderate speed (150 watts, resulting speed 23-28.5 kph) then use AnalyticCycling to extract a Crr, which they temperature-adjust using results from a control tire. This isn't the most scientific method possible, as they don't say how they adjust for Crr.. personally I like the Chung method which is similar but slightly different. They inflated tires to the Berto recommended pressure, which targets 15% drop (ie loss of rolling radius due to load = 15% of the tire radius measured laterally, on the rim). But the results are sufficiently comprehensive that they are of interest. An in any case, if I want to criticize their methods, I should do my own freakin' test.
The following numbers I pulled from a bar graph, without grid lines, by eye, so there's some potential for small error probably less than the testing precision.
The best tires are various out-of-production racing tubulars which are no longer available starting with a Challenge 33-622 tubular @ 0.25%. The Vittoria Open Corsa Evo CX 25-622 clincher (with butyl tubes) is 0.32%. The same tubulars were next @ 0.34%. Vittoria Rubino's 25-622 were next @ 0.40%. Then Michelin Pro2 Race 25-622 and Grand Bois 32-622 were @ 0.43%, Grand Bois 29-622 @ 0.44%, Grand Bois 25-622 and Challenge Paris-Roubaix 27-622 @ 0.45%, Michelin Pro2 Race 23-622 and Continental Ultra Gator Skin 23-622 at 0.47%. I'll leave it there, but the list continues to an airless tire 28-622 which measured at an incredible 1.46%.
Other lessons:
1. Air pressure has remarkably little effect on smooth roads, but on rough roads helps. Tubulars can be run at lower pressure, so this is an advantage, even if they don't necessarily have lower rolling resistance at the same pressure based on the results from the Vittoria.
2. Narrow tires don't lower rolling resistance.
The difference between these results and roller tests is credited to suspension losses, since at higher pressures the rider bounces more, which is lossy.
I was shocked at how poorly the Michelin Pro Race 2 tires did. I have Pro Race 4 tires and really like them. That the Pro2 would test close to Gator Skins, which are generally acknowledged to be slow, is surprising.
I hadn't realized the Corsa CX's were available in 25C. Those, it seems, are the winner here. But more generally that fat tires, even 32mm, can be quite fast.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Apr 06, 2013 4:11 pm
Do they test multiple tires of the same model, and even from different production lots? My guess is no. How much variation is there from tire to tire and lot to lot of the same model? Might this be more significant than some of the supposed differences between models? And then of course there is the environmental history (aging, temperature and humidity of storage, etc.) of the tires (and tubes) being tested.
PostPosted: Sat Apr 06, 2013 5:02 pm
They test different sizes in the same model, which provides some degree of control, since the different models seem fairly well correlated. I wonder if there's a significant difference between the Michelin Pro2 and later models. Notable is the Grand Bois tires don't do especially well, since the author of the study, Jan Heine, sells Grand Bois tires through Compass Cycles, speaks to his credibility. I actually really like Grand Bois tire: they mount well, handle well, and have good durability. I was disappointed to see them test so relatively poorly. The "Extra-Leger" model is of greater weight-weenie interest, and wasn't tested here.
One thing is with tubulars Al Morrison has documented that gluing technique has a strong effect, and so I would have liked to see this documented. It's hard to draw conclusions about tubulars versus clinchers otherwise.
Fuji SL/1
PostPosted: Sat Apr 06, 2013 5:36 pm
Can you explain why Crr is given as a %?
I would like to see the pressure differences for a given rolling radius
http://cds-0.blogspot.com
PostPosted: Sat Apr 06, 2013 5:55 pm
Don't forget the aerodynamic disadvantages of fat tires. Its really quite significant. And in that regard, of the tires you listed, the Vittoria when paired with a latex tube is probably the fastest.
See Zipp data on tire width, keeping in mind that the 303 was specifically designed for less penalty with 25mm tires: http://velonews.competitor.com/files/20 ... s-Zipp.png
PostPosted: Sat Apr 06, 2013 7:36 pm
Aren't the Pro2's ten years old? wouldn't that compromise crr... I know some nicer tubulars gain benefit from storage, but surely not the Pro2's?
The Shivenge
PostPosted: Sat Apr 06, 2013 9:34 pm
wondered about this use of the Pro2's as well. Michelin is already on the Pro4's so I'm confused why those wouldn't have been used or at least the Pro3's...
Looks like I made a new 90 Proof friend
PostPosted: Sat Apr 06, 2013 11:27 pm
good info.
related on the clincher front conti 4000S are winners on both CRR and aero testing
tour mag results
http://forum.slowtwitch.com/gforum.cgi?post=4127592;
slowtwitch testing
http://bikeblather.blogspot.ca/
flo wheels tested aero drag of tires on there excellent wheelsets
conti was fastest. vittoria cx the slowest
http://www.facebook.com/pages/Flo-Cycli ... 9109778769
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Sat Apr 06, 2013 11:45 pm
I'm glad they've switched to this kind of test, though of course I'm guessing that if the protocol is exactly as you describe their precision isn't very good. Here's how Heine described his Crr testing protocol last year, which involved a hill coast down, two spotters spaced 184m apart, and an unspecified way to synchronize the timing devices.
My protocol is pretty different because it's not done at either constant speed or constant power.
Some readers might find a Crr of 0.34% more familiar as .0034, but it can be handy if you recognize that Crr scales exactly like a slope, so an additional 0.1% in Crr is just like a slope which is 0.1% steeper.
PostPosted: Sun Apr 07, 2013 3:50 am
Interesting test protocol. I'm thinking they should get an e-bike where they can accurately regulate the power
PostPosted: Sun Apr 07, 2013 12:43 pm
Crr is the drag force divided by total force perpendicular to the ground, or more often just as dividid by total weight (on flat ground they are the same).
The Pro2 tests might be old. BQ has been doing tests for years, and these were a compendium. Still, I find those numbers surprising. I don't know the difference between Pro2 tires and Pro4.
In contrast, Contintental Gatorskins?
They have also done roll-down tests on a soapbox derby race track. Here they relied on gravity to provide the power. There would be a small error from differences in rolling mass as a % of total mass... but that's small.
They claim to have used a set of reference tires as a control but comparing tests done at different times is tricky. Differences in wind resistance are also a factor, as was noted, but these tests were all at relatively low speed where tire rolling resistance is still important. Variability in human rolling resistance is a greater concern, perhaps. So I think it's good to look for trends in tests like these (for example, fatter tires aren't slower; relatively lower pressures aren't as slow as one might think) rather than focus too heavily on the one particular number. But the CX Evos have consistently tested well in tests, these included, so I think it says a lot for those tires, which I hadn't realized were available in 25's.
Fuji SL/1
PostPosted: Sun Apr 07, 2013 6:17 pm
I have a very old Pro2 Race that I use as a control tire, and it tests quite fast--faster than a one year old Conti 4000S. OTOH, I have an Axial Pro 700x25 (the predecessor to the Pro2) and it's actually worse than a Gatorskin. It's immediately apparent when riding it that it's really, really slow.
So, if you have any questions about a specific tire, your best bet is just to test the exact tire. In terms of variability among tires, my experience is that all of the Lion Tyre Company tires (Vittoria/Bontrager/Zipp/Ritchey etc) are remarkably consistent (although there are significant differences among the various tires they make, obviously).
As far the gluing methods making a difference with tubulars, I recently bought a used Stinger 6 with a VittoriaEvo CX 23, glued about 1 year ago with Mastic One. I'd describe it as "poorly glued", with some of the edges easily visible if I pulled up the edge of an uninflated tire. Not unsafe, but not fast. Crr was .0039 on my rollers. After gluing it properly to minimize Crr, it dropped to .0031. So yeah, gluing method makes a huge difference. A well-glued mediocre tire can be faster than a 'fast', poorly glued tire in my experience.
PostPosted: Mon Apr 08, 2013 6:58 pm
Curious: I was browsing Google on the subject and came across this result, using a pendulum whose damping rate measures rolling resistance. There's a comparison between Continental GP 3000's (generally considered good tires) and Michelin Axial Pros:
Here''s a video of a similar system
Fuji SL/1
PostPosted: Mon Apr 08, 2013 7:23 pm
I don't know about the GP3000s, most pre-black chili Continentals were not fast rollers. The GP 3000 in 20c with butyl tube on AFMs charts is not good, in fact it's DFL(but most clinchers weren't tested with a butyl tube). But to the point of your chart, if it had a latex tube it would have been just slightly worse than the 23c Axial in his tests. And that margin may have been smaller if it had been a 23.
PostPosted: Mon Apr 08, 2013 7:42 pm
Thanks DJ, lots of good info.
Doesn't the Vittoria Evo CX have a really bad reputation for wet grip? I seem to recall having read here on weightweenies that pros refused to use it, leading to the creation of the SC. And indeed all the Vittoria neutral service cars at last year's Tour of Austria had wheels with SCs on (the only race I went to see a stage).
There are no new unread posts for this topic. Sram Red 11 Brake / Spring holder missing
ukracer
Tue Sep 26, 2017 6:39 pm
ukracer View the latest post
There are no new unread posts for this topic. Anyone riding 4iiii power meter? Water resistance?
FastforaSlowGuy
Fri Sep 01, 2017 12:10 pm
Brus View the latest post
There are no new unread posts for this topic. Fork for 2013 supersix evo 1.125->1.25 tapered
vejnemojnen
Fri Jul 07, 2017 1:13 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. 2013 Cannondale Supersix Evo Race Edition - widest tire
G6612
Sat Mar 18, 2017 12:12 pm
dmtevo View the latest post
There are no new unread posts for this topic. 2013 Northwave extreme tech SBS vs current extreme tech shoes
Delorre
Wed Apr 19, 2017 7:37 am
mrlobber View the latest post
Users browsing this forum: coriordan, hypercycler, Squashednuts and 24 guests
