It is currently Sat Jan 20, 2018 4:31 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
PostPosted: Sat Apr 06, 2013 3:16 am
looking to build up some handbuilts on alchemy ELF/ORC hubs. Would you all go with a mavic open pro or HED c2 clincher rim? I feel like people will lean toward the c2, but why? Ill be using them for everything from rainy rides to gravel to racing. Also will the alchemy hubs hold up to this use? and what spokes would yall go for? im new to the handbuilt wheel game so any advice is much appreciated.
Since that was a lot a questions... a recap!
1. Mavic open pro vs HED c2 clincher and why?
2. Will Alchemy elf/orc hubs hold up to everyday use (ie. gravel, rain, racing)
3. What spokes would you use?
Thanks!
PostPosted: Sat Apr 06, 2013 3:33 am
1) The C2 rim is much better made. High, quality and won't click.
2) Yes
3) More info appreciated. With the C2 rims you aren't locked into 32 spoke count. How heavy are you?
www.ergottwheels.com
PostPosted: Sat Apr 06, 2013 4:37 am
ah yes, i range between 170-180 lbs, so Im thinking 24 front 28 back? :noidea:
PostPosted: Sat Apr 06, 2013 5:40 am
I have the C2 tubulars built into a powertap wheelset, built 32/28 f/r with 14g non-butted spokes, as recommended by the lbs that built them.
I also have a tubular set built with Mavic's reflex rims, which are comparable to the openpro. My bikeshop said that these are a bit weaker than the Hed rims, and suggested 36/36 3x all around, again with 14g spokes.
I am not a wheelbuilder, but my LBS has a good reputation, so I trust their opinion. Since I weight 145-150 pounds, I would think 28/24 would not be strong enough for a 170-180lb rider
PostPosted: Sat Apr 06, 2013 7:23 am
36s ! ...must have no faith in wheelbuilding ability...at your size..28s....
Sent from my GT-I8160 using Tapatalk 2
tcr's rule !
stefanpearce@rocketmail.com
PostPosted: Sat Apr 06, 2013 7:31 am
Am I reading that correctly, more spokes at the front than rear? Why?
PostPosted: Sat Apr 06, 2013 10:07 am
A lot depends where you are.
I've got both, C2's on a 32h Powertap , which replaced a worn out Open Pro, and had loads of OP's built on various hubs, either for myself, or I've built for others.
Here in the UK, the C2's are damn nigh impossible to get hold of, and when you can, they're nearly twice the price of the Open Pro's. If you're going to be riding in crappy conditions , thats got to be a consideration if they're not going to last...
Mavics = readily available.
Weight wise, they are about the same. From memory they were about 435g each.
Build quality;I've only ever seen 1 of these masses of open pro's with "rattley" bits or eyelets ripping out. I'm sure there is poorer quality of both parts floating around out there, but by virtue of the mavics being a far greater seller, there are bound to be more of them.
Spoke count? Well its not too hard to get an OP in 28h, but the C2's although offered in various drillings, seemed impossible to track down..
The OP is easier to get a turbo tyre on too :lol:
Purely subjective stuff but- i'm sure i've seen a few posts on here about clearance with wider rims on various frames; might be worth checking first...
and also (as he ducks for cover) im not exactly sold on this wider is better philosophy. I couldnt really tell any difference in performance.
Cant comment on your choice of hubs, but the Alchemy's are rated highly on here.
I guess which spokes you use will be determined by which hubs you use, and spoke count and build pattern.
Happy not to have cleared anything up!! :roll:
Official cafe stop tester
PostPosted: Sat Apr 06, 2013 12:59 pm
I use both with regularity. Open pro's are the latest and greatest rim technology from 1998. They are great at what they were designed for. To simply last forever and not weigh a ton. Most companies still can't make a shallow, double eyeleted rim that compares in weight and strength. That having been said. They're not very stiff (relative to other rims) And are as aero as a brick.
The C2's are a tad heavier than the open pro's. But more than make up for it in stiffness (acceleration, cornering) and have much better aerodynamics. Plus, you get to run your tires at lower pressure with no loss in speed. This makes up the difference in comfort between the two.
So I guess it comes down to performance or lasting forever. Double eyelets make a huge difference in wheel longevity. As does the added flex.
As far as spokes go. There's no reason not to go with a butted spoke. Nobody has ever had a spoke (a good spoke that is) break in the middle. I prefer Sapim Lasers myself. But others like DTcompetitions and revolutions. I personally found the revolutions hard to keep tensioned in the past. Not so much with the lasers.
Keep in mind that thinner spokes require more tension, increasing the likelihood of cracking a C2 rim. And don't be fooled into thinking that alloy nipples are a good place to save weight. In the front, yeah. But in the rear. What you save in weight isn't worth the headache a year later when you go to true the wheel. Brass nipples with prolock(DT) or poly-x (sapim).
Just my 2 cents. But I'm sure others will have their own ideas.
PostPosted: Sat Apr 06, 2013 1:02 pm
A good point was also made on here about clearances. I couldn't use my C2 rear wheel on my Wilier LeRoi due to clearance issues. Different brakes have issues as well being opened up that far and expected to work correctly.
PostPosted: Sat Apr 06, 2013 1:46 pm
I've had a couple sets of OPs laced to factory hubs in 32 and 36.......strong wheels. You can bomb down fire roads without a worry.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sat Apr 06, 2013 6:03 pm
I have both and would definitely go with the HEDs. I have a set for training wheels built up 32 spoke on CK hubs. They survived Flanders and Roubaix without a hiccough under my 200+lb corpulent ass. They are more comfortable than my tubulars with Michelin 25C tires and plain old butyl tubes. There are new C2s coming out this year that look even better.
As someone said above the OPs are the best of technology from 20 years ago. They are solid but not worth the cost. To me if you are going to go for old technology rims, especially box section I would probably pick the Ambrosios, more cache. There are many better rims though for better prices, some of which there are lots of topics for on this forum. H+son Archetype and pacenti come to mind.
PostPosted: Sat Apr 06, 2013 6:55 pm
I was an open pro guy, until I tried DT 465. Not happy with my stan's 340 1gen at all.
Next build, I am thinking about using the hubs my stan's with DT440 rear asy and DT 415 front.
C
PostPosted: Sat Apr 06, 2013 7:28 pm
The Open Pro and C2 aren't even in the same league. The finish on the HED is much nicer and overall, I think its a much better rim than the Mavic. Don't get me wrong. The OP is bomber, but the C2 is much better.
http://www.zencyclery.com
PostPosted: Sat Apr 06, 2013 8:22 pm
@54x11
Sorry, my mistake... I meant 32rear, 28front.
PostPosted: Sat Apr 06, 2013 11:10 pm
Don't waste money on DT415's. The single eyelets are no match for the doubles. Not just in terms of strength either. The douple eyelets help stiffen the rim. Try Ambrosio Excelights if you're looking for a lighter box section. I have both as well (Yes,, I have a load of wheels) and prefer the Ambrosio's to the 415's.
There are no new unread posts for this topic. open tubulars
bennybikes
Fri Nov 03, 2017 4:36 am
vanillaflyweight View the latest post
There are no new unread posts for this topic. PSA: Wiggle Vittoria Open Pave CG - $33
Pschnei3
Tue Sep 12, 2017 5:33 pm
Pschnei3 View the latest post
There are no new unread posts for this topic. Disc brake TT open mold frame
szabozed
10
888
Tue Jan 16, 2018 6:47 pm
akafinto View the latest post
There are no new unread posts for this topic. open mold time trial frames - 'best' options?
joejack951
11
1561
Wed Dec 20, 2017 1:08 pm
szabozed View the latest post
There are no new unread posts for this topic. updated recommendations on open mold frame suppliers
apctjb
15
2328
Sat Nov 18, 2017 9:22 pm
apctjb View the latest post
Users browsing this forum: coriordan, crn, Leviathan, mattcooke, petromyzon and 51 guests
cron
