It is currently Mon Dec 18, 2017 6:39 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Fri Apr 05, 2013 6:13 am
I have just tried to fit a Campag 36t chainring to a Campag ultra torque compact crankset - and it didn't work.
It appeared to fit on the spider okay except for where it attaches behind the crank arm - the hole there was a little off-centre (towards the crank axle) and would not allow the nut to be tightened.
Does anyone know if the is a mismatch between the various Campagnolo compact chainrings and cranksets (the chainring was described as Chorus 10spd for compacts and the cranks are Centaur ultra torque compact).
PostPosted: Fri Apr 05, 2013 6:44 am
Bit of research indicates that the 36t that I have does not have the CT standard configuration of holes (4 at 110mm and 1 at 112mm distance from centre). I don't know what this chainring is designed to fit but I guess I will have to try again.
PostPosted: Fri Apr 05, 2013 1:47 pm
Yes Campy has had at least 2 styles of CT chainrings. On an circa 2004 square taper centaur CT crankset the 110 BCD was completely conventional. It may be the only occasion when Campy chainrings were made to a common standard! On the later hidden arm cranksets, the BCD is not conventional with the hidden bolt being off line, and as you have discovered, not compatible. Look in the spares catalogs online for more info.
There's sometimes a buggy.
One.
PostPosted: Sat Apr 06, 2013 4:14 pm
Shop Owner / Manufacturer
It is also worth noting that Campagnolo chainrings are not of common thickness, so there can be an issue with fitting chainrings not specified for a given crank set - the "hidden" bolt means that the chainring has to have the appropriate thickness for the cranks and spacer that you are aiming to attach it to.
The offset bolt is there so that users can't make a mistake with regard to the relative positioning of the two rings, in order that the ramps and pins and tooth profiles are correctly placed to lift & drop the chain.
PostPosted: Sun Apr 07, 2013 5:50 am
Thanks for that.
Looking at my chainsets though it appears that differences in thickness of the chainrings is more of an issue with the outer rather than the inner ring. A slightly thicker inner ring should still sit at the same distance from the outer ring at the offset point and the same spacer could be used (and bolt should still be long enough to be tightened). However, a thicker or thinner outer ring (which attaches directly to the crank arm) would cause problems as the distance between it and the inner ring would therefore vary.
There are no new unread posts for this topic. Campagnolo 53 and 36 chainring combo ?
nismosr
Sat Nov 04, 2017 2:53 am
Squashednuts View the latest post
There are no new unread posts for this topic. campagnolo centaur 11 speed chainring compatibility
JoO
Sun Oct 22, 2017 3:19 pm
JoO View the latest post
There are no new unread posts for this topic. Shifting from small to big chainring on 2015 Campagnolo Super Record
ctn
13
1156
Thu Dec 07, 2017 9:08 pm
Calnago View the latest post
There are no new unread posts for this topic. Q rings for Campagnolo 4arm crankset ?
stormur
Fri Jul 28, 2017 3:29 am
CycloTron View the latest post
There are no new unread posts for this topic. Campagnolo TOOLS UT-FC220 - Over-Torque crankset assembly and disassembly tool
moccacaffee
Fri Mar 10, 2017 4:44 am
ferrarista View the latest post
Users browsing this forum: cyclenutnz, DOUG, Google Adsense [Bot], Hapsmo911, yjymb and 36 guests
