It is currently Thu Jan 18, 2018 11:13 am
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Thu Apr 04, 2013 5:38 pm
Hi,
Just to know if is it normal to have a little space between the fork and the head tube.
(I saw there is no space for the R5 ?!)
I placed only one bearing at the bottom...Is it enough?
Thank You.
PostPosted: Thu Apr 04, 2013 8:35 pm
There really shouldn't be any space between any fork and head tube, if there's more than a millimeter-ish gap, something's likley wrong. And yes, there should only be one set of bearings at the bottom of a head tube.
Is this your first headset install? You might want to consider taking your bike down to the LBS and having someone there do the headset installation while you watch and learn. Not worth risking damaging that beautiful frame with a botched headset install, you know?
This picture shows what the fork/head tube should look like:
PostPosted: Fri Apr 05, 2013 12:00 am
Some of the R5ca's had more space than others. My guess is that it has to do with them being hand made. Ideally they should have all been exactly same and had something closer to 1-2mm of spacing, but that din't happen. You are not doing anything wrong. That is just the way they come.
There are no new unread posts for this topic. Cervelo s3 fork
trilocus
Mon Jul 31, 2017 1:57 pm
kookie View the latest post
There are no new unread posts for this topic. Attachment(s) THM Clavicula SE installation
adamdoc12
Tue May 23, 2017 2:00 am
audiophilitis View the latest post
There are no new unread posts for this topic. Campagnolo SR ITA BB cups installation method
karhu
14
852
Mon Jul 03, 2017 11:15 pm
AJS914 View the latest post
There are no new unread posts for this topic. Cannondale Quarq Installation Issues
58teeth
10
563
Fri Jan 05, 2018 3:26 pm
58teeth View the latest post
There are no new unread posts for this topic. SRAM knurled nut installation issues
octave
15
1374
Thu Aug 31, 2017 9:43 pm
Calnago View the latest post
Users browsing this forum: corky, crbeardy, tomycs and 40 guests
