Rotor 3D+ pinchbolt
Kermithimself
by Kermithimself
I seem to have lost the pinch bolt on my 3D+ crankset. Does anybody know where I can buy a new one?
If you dream of being famous - think of what birds do to statues.
Instagram: https://www.instagram.com/kermithimself/
Youtube: https://www.youtube.com/channel/UCdCPaXwpeXT_LpuEF0REjqw
Facebook: https://www.facebook.com/gotlegscycling/
DanW
by DanW
Do Rotor not say that this should never be removed? I may be wrong but it rings a bell. Might be worth asking them
rmerka
by rmerka
I thinks ok to remove it. I stripped one and was unable to find a replacement bolt. Ended up just getting a new adjuster ring. http://www.velotechservices.co.uk/shop/vclose2.asp?prd=113829&cat=7386000657
thisisatest
by thisisatest
DanW wrote:Do Rotor not say that this should never be removed? I may be wrong but it rings a bell. Might be worth asking them
You're thinking of the 3d crank, without the "+". In that case, yes, it should not be removed and would be difficult to do so if you wanted to.
the 3d+ crank has a tiny screw on its preload collar. That can be replaced if you can find one.
I'd try hobby shops with r/c models. they use very small metric hardware.
DanW
by DanW
Fair enough, apologies for the confusion!
kfreytag
by kfreytag
Just give a call to ROTOR. I snapped the head off mine the first time I did an install of one, and they sent me one right out.
Life's too short to ride clinchers.
Current:
Parlee Z-Zero ISP
Santa Cruz Stigmata CC
Past:
Ridley X-Fire Disc
jpanspac
by jpanspac
I have also lost my pinch bolt, and would rather not have to buy the whole preload nut assembly. Can someone tell me the specs for just the pinch bolt?
Thanks.
My favorite components are the ones I never have to think about.
Valbrona
by Valbrona
Hey, I've lost one too ...
