Look keo bearing service guide, any use??
a9ennis
by a9ennis
Guess the title says it all, as a long term Look Keo user I have eventually had a set of bearing fail on a set of Keo Carbons. After a quick look around this and other forums, I was surprised to see no solutions on replacement of the double inner cartridge bearing replacement (the outer needle roller is not removable, haven't tried thou). Being a mechanical engineer, thought this would be an easy repair and it is. just waiting for the new bearings to arrive but thought is their any demand for a guide to be written or a video put on You tube? :noidea:
Tricky1
by Tricky1
I was kind of in your position last year with my Keo's. I searched forums and youtube as well, but LOOK warrantied them and sent a new pair. I'm surprised to hear that new bearings are being sent, I would've thought LOOK would do the replacement work (assuming the bearings are coming from them) or just replace the pedals?
In theory the internals are fairly simple, but require a delicate touch when torquing, and the spindle threads can strip easily, especially the carbon/ti keo's. Be careful if you're doing the work...
