It is currently Fri Oct 20, 2017 12:18 pm
PostPosted: Wed Apr 03, 2013 7:38 pm
All,
I have an annoying problem. My commuting wheels are OP/DA 7900 hubs but my race wheels are carbon tubular/SL211 SuperLight rear hub. The annoying problem is the inability to simply change wheels and go; I have am forced to adjust my RD, which usually ends up with me mucking it. I have studied, much to no good, the specs for both hubs in a hope of deducing a method off installing the cassette on the BHS hub such this the cassette is in line with the DA7900 free hub.
Question 1: am I on the right track in that I could insert a spacer behind the cassette on the BHS hub in order to push it out and in line with the DA7900 hub?
Question 2: referencing "freespoke" (and/or other sources) and the BHS site, what spacer width would I use?
Question 3: any other alternatives beyond electric trimming and me becoming more proficient (mainly b/c my pit wheels are my OP/DA7900 wheels)
PostPosted: Wed Apr 03, 2013 8:32 pm
I've used a 1mm Shimano spacer on my SL211 hubs (with Sram cassettes, which normally don't use a spacer). That puts the cassette in line with my race wheels, which have White Ind hubs.
I have not twisted the 11t cog off yet but I don't make a lot of power.
It makes me wonder if a Shimano 11sp cassette would work on 10sp SL211 hubs, as they're only 1.85mm wider.
PostPosted: Wed Apr 03, 2013 8:37 pm
Hi Eric,
I will try a 1mm spacer and see where that gets me. Also, I had been pondering the same question that you raised regarding 11-speed. Perhaps here will be able to test it.
PostPosted: Fri Apr 19, 2013 3:25 am
A quick follow up before I try adding an additional 1mm spacer, do I run the risk of snapping the cassette off the hub? I rarely use the 11t cog. Also when experimenting with both spacers, the end of the cassette looks almost identical to the DA setup and feels secure without the lock ring. I feel that a Mavic spacer would be a perfect match, 1.85mm spacer
PostPosted: Fri Apr 19, 2013 6:32 am
Eric, I too run a 1mm spacer behind a Red cassette on the SL211 hub. However, I can tell you that an 11 Shimano cassette will not fit on the SL211 freehub. I thought it might, so I gave it a try last night, but the 11t cog will not catch the splines of the freehub at all. BHS now has an 11 speed Shimano hub, but no 11 speed conversion freehubs.
PostPosted: Fri Apr 19, 2013 1:47 pm
@headwind:
I would leave your cassette spacers alone if things have been working properly. The reason for discrepancy in rear shifting is different distances between the high cassette cog (small) and your drive side outer locknut or end cap. I've solved this problem by adding drive side spacers or filing down a locknut to a narrower width. Try measuring with a caliper the distance from dropout to 11t on both hubs with the wheel on the bike. Correct spacing as necessary until these distances are equal.
PostPosted: Fri Apr 19, 2013 2:30 pm
@captainclarko - for clarification, the shifting is fine specific to each hub. The issue is switching between wheels/hubs. With two 1mm spacers behind the cassette on the SL211 hub, the chain line matches up 95% and requires zero RD adjustment. The 11t feels secure on the hub groove too. I am able to secure the lock ring.
I understand what you are suggesting. Alternatively I would like to place an additional hub washer behind the free body, but I cannot seem to be able to remove it. I am two 5mm metric wrenches, but I can only remove the NDS side. I must be overlooking something. I wish Brandon had a tech section on his site.
PostPosted: Fri Apr 19, 2013 9:59 pm
Wookieopolis- thanks for trying that and reporting back.
There are no new unread posts for this topic. Replace Dura Ace 7900 Cage Rear Mech
anicell
Thu Jan 05, 2017 5:11 pm
ooo View the latest post
There are no new unread posts for this topic. REAR HUB ZIPP 188
nick007
Thu Aug 24, 2017 9:20 am
kavitator View the latest post
There are no new unread posts for this topic. hope rear hub weight
simoncx
Tue Feb 28, 2017 3:07 pm
simoncx View the latest post
There are no new unread posts for this topic. Campag SR rear mech
Timujin
Fri Apr 28, 2017 8:40 pm
mattr View the latest post
There are no new unread posts for this topic. Campy Rear Derailleur Compatibility
tomato89
Mon Nov 21, 2016 2:44 am
joeyb1000 View the latest post
Users browsing this forum: Baidu [Spider], Everyone and 20 guests
