Hi!
Does anyone know if you can fit an internal Di2 battery on the 2013 Giant TCR Adv. SL? Has anyone tried it? How does it look?
Thanks
2013 Giant TCR Advanced SL internal Di2 battery
I have the bike you mentioned and battery, although the battery is being installed in a Wilier Cento 1SR. The internal battery will fit into the Giant's ISP, although you must get creative in order to figure out how to integrate it. It's not impossible. The Wilier also has an ISP. If you want me to go into detail as to what I did to make it work, let me know.
I built one this past winter from some help in WW. I duct taped a zip tie to the battery so to hook it to pull it from the frame. Used some bubble wrap.. you won't need much.. then stuff it in the ISP. It never moved and worked perfect.. easy.
