Best modulating brake pads for carbon wheels?
HillRPete
by HillRPete
Thanks Eric, I'll stay with the Reynolds then, on Yishun/basalt.
thprice
by thprice
Tried both Reynolds Blue and Swissstop Black Prince pads on Farsports FSL24-TM rims.
  • Reynolds Blue - lasted 4800 km, good consistent braking throughout their life, good modulation.
  • Swissstop Black Prince - lasted 1800 km, very slightly stronger braking but significantly poorer modulation than the Reynolds Blue, grabby
As expected, when wet, both pads had some performance degradation, but nothing to differentiate them.
There was probably a little more life in the Black Prince pads, but I wanted to get back to the Reynolds Blue pads.
For me, a clear winner (Reynolds Blue): While a whisker weaker in braking performance than Black Prince, they have significantly better modulation and their life is also far superior.
Also tried Swissstop Yellow quite a while ago .. compared to Blue and Black Prince .. belong in the bin!!
Me: 79 kg, in the 6600 km trial, did around 100,000 m ascents and the same descents, brakes: KCNC C7.
Juanmoretime
Administrator
by Juanmoretime
Since I first posted back in April I have put of 10,000 km's on Reynolds blue pads. Great braking in both dry and wet. Actually wet performance is the same as dry. Wear has been great too. I bought a second set but even after 10,000 km they look like they could go at least another 10,000. Also they have never once squealed and have run perfectly silent.
RESIDENT GRUMPY OLD MAN.
wrcompositi
by wrcompositi
thprice wrote:Tried both Reynolds Blue and Swissstop Black Prince pads on Farsports FSL24-TM rims.
Hi, theprice, I have Farsports rims and their own blue pads are pretty good for my use(although they squeal sometimes), how do you compare the performance of Farsports' pads to Reynolds'?
thprice
by thprice
Have not tried the Farsports pads.
OhPinchy
by OhPinchy
I got a set of 50mm deep 23mm wide carbon tubs (Gigantex rims I believe) on Chris King hubs from Wheelsmith.co.uk last year. Loving the wheels but a while back during a bit of changing wheels in the dark, I left a couple of the brake pads that came with it behind. So I went ahead and bought some yellow SwissStop brakes as I find the green ones unbeatable on alloy rims and hoped the yellow would do the same for carbon.
Had no problem with them on rolling terrain but on Saturday I did a lot of climbing and they were very poor on the descents - incredibly loud screeching noises, enough to freak out everyone in my group so I dropped back and descended solo. Think there's some residue on the braking surface - what's best for cleaning that?
What are the best pads folks have found for these rims?
cajer
by cajer
Either a scotch bright pad or crazily enough an old hard eraser works on getting residue off. Additionally swiss stop black prince works pretty well on most rims
HillRPete
by HillRPete
Many, me included, like Reynolds Blue pads on various generic rims for their flawless performance. Have not used them on Gigantex specifically, though. Price is very good compared to SwissStop as well. For me the yellows were quite noisy too, much better with the blues.
Regardless what you end up with, ensure Wheelsmith approves its use.
wetpaint
by wetpaint
Reynolds blue. They're much better than SS yellow or black on Gigantex rims.
TwiggyTN
by TwiggyTN
I have found the Reynolds Blue the best on my Gigantex rims ad well. Tried the yellows with experiences like yours (you can sand the glaze off the pads and the squealing will subside until the glazing occurs again. Also tried Zipp cork and Black Prince. Blues give the best feel and best performance overall. I'm running 2006 Record brakes also.
Sent from my Galaxy Nexus using Tapatalk
RC856
by RC856
Hi,
I got a set of wheels from Wheelsmith last month and Derek no longer recommends the yellow SwissStop.
Black Prince now and I've found them good so far...wet and dry.
5 8 5
by 5 8 5
Equinox are the Gigantex approved pads.
RC856
by RC856
5 8 5 wrote:Equinox are the Gigantex approved pads.
I'd read that but Wheelsmith supply cork pads (are these the Equinox) or upgrade to the Black Prince.
OP....if in doubt, send Derek an e-mail. He replies pretty quickly :)
5 8 5
by 5 8 5
No, I got rubber Equinox pads with my Gigantex wheels from Derek last year.
bm0p700f
by bm0p700f
After trying a few Campagnolo carbon pads are just fanstastic - good modulation and bite. They even work in the wet which surprised me a lot and They do not seem to wearing the rim either. Maybe give these ago. All those cheap pads that come with various far eastern rims seem to be pretty useless in comparison. I know what pads I am supplying now.
