It is currently Sun Jan 21, 2018 8:18 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Tue Apr 02, 2013 6:56 am
i've been lurking around on ebay trying to spot some good deals on a 2013 SRAM Red groupset. some used version looks great condition and since i don't race, it should be ok. but how can i tell if they are the actual 2013 sram red and not the 2012 model?
afterall, it's not listed on the parts itself, or is it?
finally.. this may sound silly.. but any chance of tuning the 2013 to be even lighter? or should i look at buying parts separately to reduce the weight further?
PostPosted: Tue Apr 02, 2013 7:11 am
It's a bit confusing, since technically the newest Red was available in 2012, and here we are in 2013 (with a new Red announced in a few weeks)
So are you trying to differentiate between:
A) Red pre-2012 and Red post-2012 (current)...
or
B) Red post-2012 and Red 2013 (still 10spd)
or
C) Red post-2012 and Red 2013- (11 spd)
As for the second question: making it lighter, the answer is yes. Of course! You can tune anything that is stock and make it lighter. :twisted:
PostPosted: Tue Apr 02, 2013 7:14 am
hi alex... i guess what i was trying to figure out is the 2013 red that is the lightest weight over the 2012 model. i doubt the 11 speed will help me much.. i'm trying to change the components on my addictR1 into a climbing machine, yet have the speed on the flats. :)
PostPosted: Tue Apr 02, 2013 2:59 pm
You can tell if it's current Red if it looks like this
PostPosted: Tue Apr 02, 2013 3:26 pm
Moderator / Brake Pad Boy
The picture you've shown is current 2012/2013 red groupset.
Below you'll find 2010/2012 red groupset.
Note the diffrent, crank, shifters, brakes and derailleurs.
Colnago extreme-C Scott Addict SL
PostPosted: Tue Apr 02, 2013 3:37 pm
Also, remember that the 2010/2012 Red BLACK group is still available. If it doesn't look like the first photo, it's the older technology.
PostPosted: Tue Apr 02, 2013 4:12 pm
Do you mean the new style SRAM Red (shown in image 1) and how to tell if it was manufactured in 2012 or 2013?
Because you can't unless you check serial numbers with SRAM and they can give you manufacture date.....
PostPosted: Tue Apr 02, 2013 9:11 pm
Those pictures are very helpful
PostPosted: Tue Apr 02, 2013 10:49 pm
awesome.. thanks for the pics... defintely helps out a lot!
kcnc brakes... are they lighter than the current RED?
PostPosted: Tue Apr 02, 2013 10:53 pm
Many brakes are significantly lighter than the stock brakes from manufacturers. The tradeoff, sometimes, can be braking power. For example, SRAM Red's brakes are exceptionally well rated (along with Dura-Ace), but they're comparatively heavy compared to the brakes WW prefer.
KCNC has a few different brake options (different levels, C7, C6, for example) - and the reviews can be mixed depending on what type of terrain you ar riding, your weight, what pads you use, and so forth.
Right now the best "deal" for light weight might be the Planet-X CNC brakes (also under different brands) as they have relatively strong braking power and modulation. Certainly not Dura-Ace or Red, but pretty great regardless and much lighter.
Braking power will be vastly improved by choosing the right pad and using the correct pad with the correct braking surface (aluminum or carbon).
PostPosted: Tue Apr 02, 2013 10:59 pm
SRAM's April 1 teaser for 2×11
Good chance to scoop up some old 10 speed cassettes at a good price, I suppose.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Tue Apr 02, 2013 11:05 pm
I just did, actually! XG-1090 heading my way for a nice sum.
PostPosted: Wed Apr 03, 2013 1:05 am
alex.. where did you score some XG-1090 for cheap? also.. SRAM Red group shifts like butter and quiet? i've always used ultegra.. so either way it will be a big change for me. :)
PostPosted: Wed Apr 03, 2013 2:12 am
SRAM in general is best described as a very direct and mechanical-sounding click. Similar to Campagnolo maybe in the 'thunk' of the shifting of gears. Shifts well though, just as all groups shift well regardless of tier. What you're getting with Red is the loss in weight and the 'latest tech' as the lower levels get features trickled down from the top.
Shimano shifting by comparison is very quiet and 'smooth' in feel.
Campagnolo has its own flares and values too.
I suggest you stop by a local shop or ask a friend and try to get a test ride in on a Campagnolo and a SRAM drivetrain to see what style you like best in feel, sound, lever shape for your hands, and action method. They're all different and they each work very well! Top tiers for Shimano, SRAM, and Campagnolo are always going to be the lightest (and most expensive).
PostPosted: Wed Apr 03, 2013 5:38 am
thanks for the tip.. maybe i'll swing by LBS over the weekend to give it a try. my friend recently upgraded to the 2013 dura ace and he said it shifted like butter. for me, my goal is to drop the weight on my addictR1... it's way to heavy now.
i don't mind the mechanical sounding click.. probably will sound like a 1DX when pressing the shutter. :)
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 6 ]
Shrike
75
12011
Thu Dec 14, 2017 7:12 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Fork for 2013 supersix evo 1.125->1.25 tapered
vejnemojnen
Fri Jul 07, 2017 1:13 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. 2013 Cannondale Supersix Evo Race Edition - widest tire
G6612
Sat Mar 18, 2017 12:12 pm
dmtevo View the latest post
There are no new unread posts for this topic. wheel clearance issue 2012 Cervelo R5 VWD
Tricky1
10
1036
Wed Apr 12, 2017 1:55 am
sugarkane View the latest post
There are no new unread posts for this topic. 2012 Cannondale Slice 5 VS 2014 Stradalli Phantom II
Alpine318is
Tue Mar 14, 2017 7:43 am
jekyll man View the latest post
Users browsing this forum: arthurf, iamalex, maxxevv, Zakalwe and 38 guests
cron
