It is currently Sat Jan 20, 2018 4:42 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: Stock weight CAAD10
PostPosted: Sun Mar 31, 2013 10:56 am
Hi all,
I tried to find the stock weight of a CAAD10 size 54 with ultegra, but I cannot seem to find this information when using google. So I though that some of you might knew or had better google skills.
A very much hope you will respond
Regards Lars, Denmark
 Post subject: Re: Stock weight CAAD10
PostPosted: Sun Mar 31, 2013 1:16 pm
Google
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sun Mar 31, 2013 1:48 pm
Although not a size 54. According to this document a size 51 is 7.6 kg
http://bmv-cykler.dk/wp-content/uploads ... eights.pdf
Sent from my iPad using Tapatalk HD
PostPosted: Sun Mar 31, 2013 3:30 pm
The first hit on the Google search I linked had the following for a white frame:
CAAD10 Frame 54cm = 1248 (Cage Bolts, RD Hanger, Seatpost Clamp, Guide)
CAAD10 Fork = 406
CAAD10 Bearings = 48
CAAD10 FSA Compression = 48
CAAD10 Other Parts = 42
Fuji SL/1
PostPosted: Sun Mar 31, 2013 5:44 pm
Cannondale says 16.7 pounds in size 51 w/o pedals
PostPosted: Mon Apr 01, 2013 9:20 pm
Thanks all, but I see that no one actually knows the total weight of the CAAD10 2013 s54 with ultegra, so I guess I just have to buy it and tell you ;)
PostPosted: Tue Apr 02, 2013 11:21 am
Yes, let us know.
Without pedals I'm guessing 8kg or thereabouts.
I see C+ have a Liquigas 56m 105 without pedals at 8.3kg
Not light. Though with a WW BB30 chainset and some light tubular rims, you can get <6.8kg easily.
PostPosted: Tue Apr 02, 2013 2:39 pm
My 56cm Ultegra with stock wheels (Conti GpP4000s tyres), 105 pedals, 2 carbon bottle cages comes in right at 19 pounds. Right at 17 with Planet-X 50mm tubulars (Conti GP4000) and Ultegra Carbon pedals.
PostPosted: Tue Apr 02, 2013 6:15 pm
In my view, asking for whole bike masses is always subject to too many sources of variability. Swap the tires, swap the tubes, swap the bar tape, add or remove bottle cages, change the saddle: these could be hundreds of grams one way or another.
Fuji SL/1
PostPosted: Wed Apr 03, 2013 5:47 pm
Yes, it was also just to make some kind of prediction what a realistic weight saving program could be when having a tight student budget.
Unfortunately, im living in a country, where tubulars is not an good idea, since punctures is part of everyday life here.
Originally I hoped for a sub7kg, but i see it might be unrealistic.
On my list when it comes is
* Speedplay - whatever model that fits my wallet
* Replacing Cannondale stock seatpost, stem and drop to 3T team series, arx, ergonova and doric
* Another saddle - probably fizik arione or SLR
I dont really dare to save weight on tires, and wheel replacement seems to be too expensive.
PostPosted: Wed Apr 03, 2013 6:36 pm
Well, the obvious tyres and tubes etc. could be changed without compromising puncture resistance much/at all.
Actually a SRAM Red Exogram BB30 chainset would be a decently cost-effective
way to lose weight vs. stock.
Then I'd save for wheels. If weight is the priority and they have to be clinchers then a build around some Stans rims at 1300g odd will save a lot of weight.
PostPosted: Wed Apr 03, 2013 6:45 pm
usual suspects would be relatively cheap and drop good few hundred grams, px brakes, supersonic tubes, uno kalloy stem, cables, tape, ti bolts, skewers....
PostPosted: Fri Apr 05, 2013 2:04 pm
Thanks a lot guys for ideas and insight! I appreciate that!
I'm so much looking forward to get it!
PostPosted: Tue Apr 21, 2015 8:04 pm
I'm sitting next to my brand new 2015 CAAD10 ultegra - black. I have a pair of Shimano 105 pedals and two blackburn cages, and an empty back pouch and it just weighed 17.11 pounds at the shop.
PostPosted: Wed Apr 22, 2015 2:13 am
That sounds right. The 2014 I just built up with Ultegra, krysium SLEs, C1 bars and an FSA SLK post was 17 on the nose. But not for long...
There are no new unread posts for this topic. Help me get below 17lbs for stock CAAD10 105... on the cheap
[ Go to page: 1 2 3 4 ]
Morghulis
56
5937
Thu Jun 29, 2017 12:40 pm
JDEves View the latest post
There are no new unread posts for this topic. going from stock 11-30 to 12-25 cassette ==> would you shorten the chain?
Delorre
Mon Nov 27, 2017 3:02 am
TonyM View the latest post
There are no new unread posts for this topic. Caad10 sub 7kg with Vector 2 Project
sgergole
Tue Feb 14, 2017 4:30 am
nemeseri View the latest post
There are no new unread posts for this topic. Cannondale CAAD10 - Stem Torque for Carbon Steer
steelandbananas
9
1111
Sat Feb 11, 2017 6:11 pm
Hamfist View the latest post
There are no new unread posts for this topic. FMB Competition CX Weight
ab01ns
Fri Feb 10, 2017 7:07 pm
ab01ns View the latest post
Users browsing this forum: AJS914, Aya, Baidu [Spider], dbnm, raisinberry777, taztaylortaz and 27 guests
cron
