It is currently Sun Jan 21, 2018 9:59 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Sat Mar 30, 2013 11:50 am
I've searched about this but getting accurate information is proving difficult...
I ordered some Swiss Stop Green pads to use on my 2009 Campagnolo Centaur skeleton brakes. They were listed as '10 speed' compatible on the retailer's website.
The pads they've sent me are 2011 RacePros which are labelled "fits Campagnolo 2011 Super Record/Record/Chorus". Will these also fit my brakes? I don't want to open the packet until I'm sure, and the retailer has failed to get back to me with an answer.
Thanks!
Blog: http://thesetbackpost.com/
PostPosted: Sat Mar 30, 2013 1:51 pm
From my understanding the newer pads will fit the older shoes. The newer pads have a cut out for the shoes on the newest brakes. I just bought some prince pads and they fit the older 2009 SR holders.
PostPosted: Sat Mar 30, 2013 5:53 pm
You should be Ok....these will fit.
www.royalbicycles.com
PostPosted: Sat Mar 30, 2013 7:17 pm
yes. the new pads will fit the old brake shoe, but the old pad should not be used in the new 2011 onward brake shoes. it has to do with the cut out in the pad to accomodate the new springy holding hinge thing.
PostPosted: Sat Mar 30, 2013 8:11 pm
Thanks guys!
PostPosted: Sat Mar 30, 2013 8:24 pm
Also...never move the bike backwards (reverse) with the brakes applied!!!! On the older campy brakes this can cause the pad to come off the holder.....this is why Campy redesigned to the new version with a safety pin.
PostPosted: Sat Mar 30, 2013 8:28 pm
I've heard that warning before but I'm scratching my head trying to think of a real world situation where that's an issue. Certainly hasn't been so far.
PostPosted: Sat Mar 30, 2013 8:34 pm
Hmmm....try to imagine you are at a traffic light and you start rocking back and forward you bike with enough brake pressure....something some cyclists do when unclipped from their bikes... I know, what are the chances but I have seen it in person!
PostPosted: Sat Mar 30, 2013 9:55 pm
I suppose. I guess I have something else to be paranoid about then. :)
PostPosted: Sat Mar 30, 2013 11:58 pm
Highly unlikely. Campag pads are a very tight fit in the pad holder. I assumed they'd redesigned the fitment to ease the pain of fitting new pads.
PostPosted: Sun Mar 31, 2013 12:25 am
True story. Last summer I switched back to my alu wheels for a trip to Italy. I had trouble getting one of the pads in and because I'm lazy I actually rode it about 3/4 inserted. Over a week of mountain riding, including high speed descents with heavy braking, the pad didn't move a mm. I'd expected it to work it's way into the shoe, but it didn't. I guess some pads are tighter than others though. (These were stock Campags.)
PostPosted: Sun Mar 31, 2013 2:49 am
But it does happens as I have seen it......
PostPosted: Sun Mar 31, 2013 4:12 am
I have 10-speed Record brakes and I've replaced the pads 3 times with Swiss Stop Green: no problems whatsoever (but they are a very tight fit).
KAC
PostPosted: Sun Mar 31, 2013 9:29 pm
I've just fitted them by the way and they're fine.
PostPosted: Sun Mar 31, 2013 11:17 pm
Tubbie Guru
Hi,
Spot on.
Anything else is down to incredibly gross user error really..... As in people riding their bikes backwards with the brake engaged applying enough force to dislodge their brake pads.
Highly unlikely. It worked for decades if not a century. Yet there's always that bright individual, I guess....
Ciao, ;)
There are no new unread posts for this topic. Swiss Stop Flash Evo BXP thickness
Steve K
Mon Mar 13, 2017 8:50 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Campagnolo compatibility 10s veloce rd - 11s athena shifters
silvalis
11
1050
Tue Jun 06, 2017 5:11 am
silvalis View the latest post
There are no new unread posts for this topic. campagnolo centaur 11 speed chainring compatibility
JoO
Sun Oct 22, 2017 3:19 pm
JoO View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo brake issue
Tricky1
Thu Nov 02, 2017 11:10 am
jekyll man View the latest post
There are no new unread posts for this topic. Campagnolo Delta Brake O rings
c60rider
Fri Jun 23, 2017 7:48 am
kgt View the latest post
Users browsing this forum: Broady, brumbar, GothicCastle, silvalis, Squashednuts and 40 guests
cron
