It is currently Tue Jun 27, 2017 5:12 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Fri Mar 29, 2013 9:13 am
Hello guys, just joined WW.
Just ordered a pair of 2013 eebrakes with the new updated cable adjust screws, somehow unable to fit the Alligator I-links cable stop into the adjust screw. The cable stops were too big in diameter. However have seen the cable stopper fit in the adjust screws in the following URL. Any help please ? :cry: Anyone using I-links with the new eebrakes?
http://www.cyclingtips.com.au/2012/02/bikes-of-the-bunch-cyfac-absolu/
PostPosted: Fri Mar 29, 2013 9:54 am
Reg the assembly on this pic, my guess is that the alloy housing is sitting on the stopper, not going inside.
Why not putting the housing other way round?
In this case housing nicely jumps into the adjusting screw, or you can use stopper between housing and screw if you want.
http://www.flickr.com/photos/90178027@N ... /lightbox/
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Mar 29, 2013 10:07 am
http://www.flickr.com/photos/90178027@N ... /lightbox/" onclick="window.open(this.href);return false;
Thought of that, but I liked the idea of having all of the i-links coming at the same direction from the bars. :?
PostPosted: Fri Mar 29, 2013 11:02 am
Neither of you are doing it right.. There is a step down segment in the ilinks kit. Fits into the EE adjuster just perfect and doesn't require you running the housing backwards which makes no sense as any water running down the housing will do its best to enter the system :|
Skunkworks Bikes
PostPosted: Fri Mar 29, 2013 11:27 am
Doesn't fit in mine.. :cry:
PostPosted: Fri Mar 29, 2013 12:02 pm
File it down.. There are few differnt step down segments.
Get some cailpers and measure things up. Get a nice fine file out and make the step down fit.. A bit of man craft is good for the soul :D
Skunkworks Bikes
PostPosted: Fri Mar 29, 2013 12:25 pm
So the ones on your Parlee are filed down ?
PostPosted: Fri Mar 29, 2013 12:42 pm
Older model brakes, but the fitting went straight in:
PostPosted: Fri Mar 29, 2013 12:46 pm
I see, but with the newer cable adjustment screws, they have a small internal diameter. :(
PostPosted: Fri Mar 29, 2013 1:27 pm
At first I filed down about 3 lengths of housing to make them 5.0mm then I realized that the ilinks come with a 5.0mm housing stepdown
Get some cailpers and measure some tjngs..
I'm pretty sure you have the same adjusters that I Do you just need to work through the available parts to find he right onesZz
In the picture the stepdowns you need are In the bag in the bottom right hand corner
Skunkworks Bikes
PostPosted: Fri Mar 29, 2013 1:31 pm
Thanks sugarkane, will do a quick search when I get home, otherwise I am prepared to file them down! Nice bike btw!
PostPosted: Fri Mar 29, 2013 1:58 pm
I know this has been asked and answered before, but it seems like the answerts comflicft and the products have had slight changes so here goes.
Has anyone had success with mini I links and the smaller diameter powercordz for shifters?
Thanks
PostPosted: Fri Mar 29, 2013 7:26 pm
I found the easiest way to take a housing-end down was to put it into the chuck of my drill, then hold it against a file using light even pressure. I then gave it a coat of black paint to match the rest of the iLinks.
There are no new unread posts for this topic. Attachment(s) Alligator I-Link Brake and shifting system
BigPoser
19
940
Tue Mar 14, 2017 4:24 am
sugarkane View the latest post
There are no new unread posts for this topic. KMC Missing Links
Valbrona
Wed Jan 11, 2017 3:57 pm
Valbrona View the latest post
There are no new unread posts for this topic. Alligator Ilink / Mini Ilink
Luca79
Tue Apr 04, 2017 12:34 pm
Mep View the latest post
Users browsing this forum: Baidu [Spider], NiFTY, Yahoo [Bot] and 48 guests
