It is currently Thu Apr 27, 2017 2:56 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Fri Mar 29, 2013 7:06 pm
If I am not mistaken, that is how the Venge was actually born was it not? They took the old Transition out with road bars and started looking into a very aero bike.
HUMP
Why are the best things in life always the ones you start last?
PostPosted: Fri Mar 29, 2013 7:45 pm
mattjevans wrote:
wingguy wrote:
Leaving aside why an SC9 is rolling on Aksiums in the first place
Holy snobbery Batman! :D
It's not snobbery, it's economics. The amount that you pay for the frame is high, but by fitting such a low end set of wheels you give away a fair chunk of the performance you've already paid for. A better balance of lesser frame and better wheels would be faster and cheaper.
PostPosted: Fri Mar 29, 2013 7:54 pm
NGMN wrote:
Depending on the requirements of your road fit and what size SC you have, it may be doable without looking like a freak.
For instance, I'm a fairly average dude and here is how it would pan out for me:
my road bike coordinates are as follows:
~380, ~550 (~10cm stem, and 80mm reach bars)
My tri bike coordinates are:
~395, ~505
But both are in essence, "slammed." And my road bike, I ride with a classic bend bar, so switching to a flat transition shallower bar would get me another 1cm in height to my hoods position and maintain my drops position.
So I would need to find an addition 3.5cm height and reduce reach by 1.5cm. 9cm stem on shorter/shallower bars - not bad for a guy on the smaller size, which I am. 3.5cm height is where you really have the potential for a not so attractive looking bike, maybe try a 0 degree stem, or -4; but you'll still need some spacers.
I'll need a 90mm stem I think - the steerer stub makes the calcs a bit more problematic, so there is going to be some trial and error (ie cheapish stems from ebay) involved. If 90mm with 6 degree rise works, a Tririg Sigma will get slapped on to make this truly cable-stealth.
PostPosted: Fri Mar 29, 2013 7:56 pm
Chill, I was kidding. I get the point completely. It could perhaps have been worded with a bit more subtlety?
PostPosted: Fri Mar 29, 2013 7:59 pm
shoemakerpom2010 wrote:
I kind of get what your looking for. I almost did the same thing when I seen a cannondale Tri bike new on sale at a local shop when I was looking for a road bike. I am like you in that I only have time in the week for some shorter rides along with commutting. I will say this when I did a charity ride over the weekend 9 guys out of the group of 12 backed out at 60 miles from the 100 that we were going claiming the extra 40 was too much. All 9 of those guys had tri bikes which leads me too believe the positions are probally not that comfortable on higher milage.
Yeah, definitely not thinking this is for high mile rides. If I was doing something like that I'd probably just buy a Triban from Decathlon or on ebay...
PostPosted: Fri Mar 29, 2013 8:02 pm
spud wrote:
I've done this, converting a Cervelo P3 to a road bike. It rides just fine, provided you don't mind a little more weight on your hands, and slower steering. Maybe it isn't the best set up for a century, and I can only hold one bottle, but overall it's fun, and definitely fast on the flats.
Thanks - good to know.
Someone just sent me this - Inspring !
http://www.flickr.com/photos/summitbicy ... 256596918/
PostPosted: Sat Mar 30, 2013 12:35 am
ha that's the one I have seen before. Looks great!
PostPosted: Sat Mar 30, 2013 3:52 pm
It does - the cabling isn't as clean as I'd like to see - part of that is the di2 box hanging out there, part is that the bars aren't internally cabled, and also the stem is quite long by the looks of it (I'd guess 120) and that make the cables look a little untidier.
Should also be using a spacer under the stem clamp.
I have the white 9.9 paintjob so it looks like white bar tape is the way to go
PostPosted: Fri Apr 26, 2013 5:19 pm
The good news is this project is slowly progressing. SRAM Red brifters have arrived, Bontrager alloy bar bought, arrived and subsequently returned so I can get the carbon version. ISM Adamo saddle sold and SLR Kit Carbonio Flow purchased (happy birthday to me). 35mm setback seatpost head acquired. 3T 90mm stem (hopefully not fake) bought from ebay, thinking I should also buy an 80mm to be able to experiment with position a bit.
The bad news is that in changing my saddle and dropping my seatpost I over-torqued (well torque was not exceeding the stated maximum but apparently the maximum labelled is incorrect, or as Trek like to say "an absolute maximum and you may not want to torque this hard", as I subsequently found by looking on slowtwitch) the seatpost clamp and C-R-A-C-K. It's not too bad but I guess a UCI seatpost just came up the priority list...
Once carbon bar arrives, wheel project is complete, and funds for a new seatpost are available, it's off to an LBS (or in this case most likely a not-so-L BS).
PostPosted: Sun Apr 28, 2013 2:45 am
Do you have any before/after type photo's so we can have a comparison between looks and setup?
PostPosted: Sun Apr 28, 2013 9:06 pm
Photos will be coming but not until I'm done
Just found that it appears with a Kit Carbonio saddle I apparently need to change out the Bontrager seat post head "ears" for specific oversize rail versions - can anyone confirm if that is correct ?
Also for a 50mm Planet X tubular rim, what size Zipp valve extenders? 48mm?
PostPosted: Sat May 25, 2013 7:03 pm
Now with decent wheels, per conversion project. Non UCI seatpost in this pic
PostPosted: Sat Jul 27, 2013 3:47 pm
viewtopic.php?f=10&t=116286
There are no new unread posts for this topic. Attachment(s) Adjusting aero bars on trek speed concept
Mattparlane
Mon Mar 20, 2017 4:42 pm
jekyll man View the latest post
There are no new unread posts for this topic. Trek Concept Bike 2026....
mile2424
Sun Aug 28, 2016 4:25 pm
KarlC View the latest post
There are no new unread posts for this topic. Selecting between an Aero Road bike vs a Time Trial bike?
THUNDERHORSE
37
4621
Sat Nov 26, 2016 5:52 pm
Lelandjt View the latest post
There are no new unread posts for this topic. help building up a single speed bike
atlasspeaks
25
1744
Wed Nov 09, 2016 6:55 pm
bremerradkurier View the latest post
There are no new unread posts for this topic. Colnago c60 or concept?
markyboy
28
2148
Tue Apr 25, 2017 8:16 pm
alistaird View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Johnny Rad, kookie, sib, tibikeboy and 33 guests
