Best Aero Bike Choice ?
JensW
by JensW
BMC or go for a Neilpryde Alize that got really good results in the german bikemag Tour aero bike test,
davidalone
by davidalone
depends on what you're going to bes mostly doing with it. racing? road races/ crits? hammerfest rides? ceenturies?? etc.
itsacarr
by itsacarr
I know you don't see a lot of them right now but Felts AR1 is a fine choice - one of the first, still tests super fast, and it's one of the more comfortable\stable frames of the bunch.
jmorgan
by jmorgan
itsacarr wrote:I know you don't see a lot of them right now but Felts AR1 is a fine choice - one of the first, still tests super fast, and it's one of the more comfortable\stable frames of the bunch.
The new 2013 AR is lighter which is nice but still heavy and is probably the least stiff out of all of the bikes so other then comfort not a huge selling point.
I love my S5, Venge is a good bike also.
Test ride as many as you can and go with what feels the best. They are all good bikes at this level.
2012 Cervelo S5 Team
stanseven
by stanseven
drewb wrote:You can add Trek Madone (having come off a Foil which is a brutal ride), I love my 3 month old Trek - except for the bontrager brakes that I replaced with Dura-ace. Less of a go-kart type of ride, less tiring.
Except a Madone isn't an aero bike. I think the OP is interested in just aero
NGMN
by NGMN
Well, that kind of gets in to a whole debate now doesn't it. Obviously "aero" is just as much a marketing term as it is a quantifiable element to any bike. To that end, the Madone has less drag than their old Madone, and less than the Storck recommended earlier in this thread. So its "more aero" than something.
Bikes now come on a spectrum of true aerodynamic performance. From the S5/Venge/Ar which have all tested fairly well; to the middle grounders like the Foil/Litespeed; then the "we're better than our last model" Madones/RcA of the world and finally, the I don't give a damns like the Supersix.
Some bikes are hard to quantify, like the TMR01 or Alize which did well in the recent Tour test but really wasn't up against any of the bikes that have typically done very well in the tunnel. In terms of the TMR01, its got lots of "tricks" but it seems to lack the one trick that always works, 3:1 tube shapes.
btompkins0112
by btompkins0112
The Madone is certainly an aero bike....Kamm tail, shielded "integrated" brakes....what more do you want?
NGMN
by NGMN
As a follow up to my post regarding the Madone; some people may want 3:1 tube shapes. The Madone, based on data released so far; performs better than the previous model but not in the same world as bikes that really sliim down their tubes.
jmilliron
by jmilliron
Best aero bike is the Wilier Cento1SR. No question!
(I'm not bias, I swear)
itsacarr
by itsacarr
I would agree with just testing some of these things out.
For the record though my 2013 AR1 frame set weight is about 1100 grams which puts it right in line (just above) an s-works venue .. that also puts it somewhere between the VWD and Team S5 frame sets so counting grams between the frames probably wont tell you much about which is faster.
All neat bikes though regardless.
sawyer
by sawyer
What size is your AR1?
In answer to the OP ... go for a Venge. I had the same first world choice problem and bought a Venge.
Read the reviews, look at the data and it's obvious why.
If you don't like the way it looks on the other hand ... .
itsacarr
by itsacarr
54.
And you're right - at least all these bikes mentioned above are different enough that if you're particular you are probably going to like or not like each one - no real in between :)
dereksmalls
by dereksmalls
What about the Ridley Noah Fast? Image
r_mutt
by r_mutt
is the campagnolo bullet 50 available in those graphics? i've never seen that before. i prefer that to the "new style" graphics.
Mattias Hellöre
by Mattias Hellöre
Rolo is a good candidate.
http://rolobikes.com/
Experimental Prototype
