It is currently Mon Mar 27, 2017 1:55 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Mon Mar 25, 2013 6:17 pm
So, I absolutely hate putting new shift cables in sram red shifters. Almost never goes smoothly and I've tried all the tricks. I can get it done but its frustrating trial and error.
So I'm wondering, are powercordz easier or harder. If its harder to do no way am I going to try, if easier (and it seems like between them being flexier and not having a rigid iniual stran to catch and bend they may be) I'll likely give it a go next time.
PostPosted: Mon Mar 25, 2013 6:36 pm
Life would be too perfect :)
Brake cables - very straight forward job, no bends.
With gear ones, I found that PC take corners much easier than steel cables.
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Mon Mar 25, 2013 6:59 pm
I tested derailleur cables for them years ago-- it was the 1.5 mm cables. They went in ok, but over time they shredded causing crappy shifting. Fortunately, the shifting got so erratic they cables had to be changed before they would break.
I never got to try the 1.2 mm cables, but I believe they work much better.
hope that helps.
FWIW, I've found getting any (derailleur) cables thru sram red shifters is hit or miss. It'll either go right through or it'll be a total PITA!
Speedplay is the devil!
PostPosted: Mon Mar 25, 2013 8:08 pm
i've used powercordz (with nokon) with my sram red almost three years, works perfectly
a while back i posted some install info here...
viewtopic.php?f=3&t=92700&hilit=powercordz&start=15#p812939" onclick="window.open(this.href);return false;
needs attention during install to make sure cables are nicked, i'd be wary of running them through traditional outer
current cables have been on over 18 months, no sign of any fraying or casing damage
There are no new unread posts for this topic. ee brakes + powercordz
sungod
9
718
Sun Mar 12, 2017 2:03 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. Engage Gravial brakes with Powercordz Swift
Kayrehn
Thu Aug 11, 2016 12:49 pm
Kayrehn View the latest post
There are no new unread posts for this topic. Which power meter: Sram Red + Stages or Quarq Dzero Sram
[ Go to page: 1 2 3 4 5 ]
Shrike
68
4303
Sat Mar 18, 2017 7:32 pm
NiFTY View the latest post
There are no new unread posts for this topic. SRAM 2 Fsa
Wull
Wed Jun 15, 2016 9:00 pm
Wull View the latest post
There are no new unread posts for this topic. Best Sram Aerolink Pad
KWalker
Mon May 02, 2016 8:01 am
Marin View the latest post
Users browsing this forum: dwiller, parleez1, rcb78, silvercivic27, springs and 13 guests
