It is currently Mon Jan 22, 2018 9:35 pm
Post new topic  Reply to topic  [ 539 posts ]  Go to page Previous 15 6 7 8 936 Next
PostPosted: Thu Jul 04, 2013 5:53 pm
My current bike does fit - but its the only fit I have ever known. I'm wondering if the 58 would fit me "better". I do have consistent hand numbness problems - though I have been properly fitted on my bike. The only thing wrong with my current fit that has been pointed out to me is that my handlebars are slightly too shot in width.
I do have a unique build. Square like - that is, the width of my arms is the same length of my legs.
The problem is, I'm not sure what aspects of my fit could be improved as this is the only road bike I have ever been on. I couldn't tell you if my reach is off or not. Are there certain things I should be aware of next time I take my bike out to determine what will make a better fit when purchasing my next bike?
PostPosted: Thu Jul 04, 2013 6:51 pm
Those numbers are pretty close to mine. I was fit on a 58 and I always felt like it was too big so I took it upon myself to size down to a 56. I feel like my fit is much better now. I guess I am between sizes and I have always heard to size down.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Jul 04, 2013 7:42 pm
Hand numbness might be caused by too much weight on your hands, and the excess weight is often the result of the saddle being too far forward. Your LBS is likely to suggest raising the bars to solve the problem, but that's not the proper solution.
With your long torso, what stem length are you using?
The reason that I mention stack and reach is that there are only small differences between frame sizes and a 56 or 58 can be made to fit the same. The 58 would use 2cm less spacer under the stem and probably one size shorter stem.
PostPosted: Thu Jul 04, 2013 8:14 pm
Stem reach (c-c) is about 3 and 3/4 inches. 9.5 cm 95mm
PostPosted: Thu Jul 04, 2013 9:16 pm
+1 on a 56 if size is the ETT particularly since you are using 95mm stem. I will take a smaller bike than a slightly larger (longer TT) bike. If you have the flexibility to get your back lower, I would say go for 58 but be forewarned that it may cause you numbness in hand and neck.
PostPosted: Thu Jul 04, 2013 10:37 pm
It makes no sense to try a larger frame is you're using a stubby 90-100mm stem. That's probably a fitting error too. With a long torso, 110-130 would be more common.
PostPosted: Fri Jul 05, 2013 10:31 am
Mr USPS...
Having seen your bike in the intro gallery, one of the things thats probably confusing you is your bike.
Those old madone's had notoriously short headtubes, so its posssible that is the reason you were getting uncomfortable, as you could be getting weighted more on the hands.
Like daveS says, manufacturers sizing means very little. I ride 51.5, 52 54 and 56cm bikes depending on who's it is..
Go round the shops and try as many different bikes and "shop experts" as you can. You will know when it feels right and whether what they say is BS....
Official cafe stop tester
PostPosted: Tue Jul 09, 2013 5:50 pm
I used the sizing guide on the canyon website and it put me on a 60/XL sized bikes. Right now I ride a XXL/61 scott cr1(pre addict one) with a 130mm -17 degree stem with 5mm of spacers under it. My fit feels good right now. I am 192cm tall, cycling inseam of 91cm, saddle height at ~83cm. The aeroad head tube is shorter geometry wise than on the cr1 I believe. I contacted canyon about if my seat height is possible on a L size aeroad and they told me "yes but with the post extended to the max line". What would you say guys? Size down or go with an XL.
PostPosted: Tue Sep 17, 2013 12:19 pm
Hey everyone!
Im kinda new on this forum, but been lurking here some time now. Being this my first comment, please bare with me, and excuse me, if my question is stupid. I've been riding track frames for the past 8 years now. I had a 55 cm frame, which was great. Right now i ride a 54 cm track frame with a 130mm, -10 thomson stem, no spacers, with Ritchey Logic II. road bars, and with a straight seatpost, had no problems riding 100+ kilometers with this setup. I'm 176 cm tall, and 70 kgs. I have pretty long arms. I'm really flexible, as i did springboard diving for 3 years, and stretching was a really big part of everyday training. Right now im gathering parts for my road bike project, so finding the right sized frame and parts is a big question. I'd like to get a very similar position on my future road bike. I know, its two different kind of bikes. I've read a lot about this topic, but theres so many opinions. I'd like to use a 130mm stem, with straight seatpost, without spacers. My main concerne is that, if i get a 54 cm frame and set it up with a 130 mm long stem + brake hoods (+60mm or more), than my reach might be too far. I'm thinking about going down one frame size, 52 cm. I know this is a very difficult topic and it depends a lot on body dimensions, arms lenght, neck lenght, hip flexibility and so on... What do you guys think? Anyone with similar height, riding a 52cm frame using long stem? Thanks in advance!
PostPosted: Wed Sep 18, 2013 2:08 pm
esfrost wrote:
Hey everyone!
to start with, can you let us know where the contact points are of the fit that you would like to replicate ?
saddle height, saddle setback (make and type of saddle), handlebar drop and reach as in nose of saddle to centre of top of handlebar
PostPosted: Wed Sep 18, 2013 8:02 pm
Sure, and sorry for the lack of info.
Saddle: Selle Italia SLR
Saddle Height: 175mm (from the top of seatpost collar)
Saddle Setback: 0. (Thomson Elite, Straight, the saddle sits in the middle of the rails)
Handlebar: Ritchey Logic II. - 82mm reach, 142mm drop
Saddle to centre of top of handlebar: 565mm
I hope this helps.
Thanks in advance!
PostPosted: Thu Sep 19, 2013 1:23 am
Hi,
I ride a 56 cannondale ss evo but plan to downsize my frame to a 54.
I'm 181cm tall with a 83cm inseam. bb to saddle is 73.5cm.
My current 56 frame has a 15.5cm headtube, where the 54 size has 14cm.
I only use the 25mm supersix conical spacer under my -12deg/110mm stem(115mm actual)
To be able to simulate the drop of a 54 frame by using the same conical spacer again, i lowered the stem 1.5cm and took some pictures.
What do you think about my downsize choice?
Note:Drop will be about same, and reach will be 1.5cm closer with a 54 frame, different from the pictured 56 frameset
When looking at the pictures, i also find out that, i have to lower my seatpost about 0.5cm(last picture) :mrgreen:
PostPosted: Mon Sep 23, 2013 5:31 pm
Yes, based on the last picture, your seat is obviously too high, unless you're sitting on the far back edge of the saddle in that one. It looks like more than 0.5cm.
PostPosted: Tue Sep 24, 2013 6:41 am
I hope this helps.
Thanks in advance!
not really
we're looking for saddle height as from the centre of the crank axle to the to of the saddle measured along the seat tube
handlebar drop as in the difference in height (measured from the floor) between to of the saddle and the top of the handlebar
PostPosted: Tue Sep 24, 2013 6:51 am
Boralb wrote:
Hi,
it looks like you sit too high, but by more than 0,5 cm
can you verify the 73,5 bb axle to top of saddle (measured along the seat tube), it looks quite a bit more
i have a 54 with 2 cms less saddle height, but the saddle sits quite a bit closer to the top tube than yours
i am considering going to a 52
There are no new unread posts for this topic. C60 Disc Hexlock - bike fitting?
Disc0
Mon Nov 13, 2017 3:13 pm
Disc0 View the latest post
There are no new unread posts for this topic. bike build questions...
izz012
26
1915
Wed Oct 04, 2017 11:21 pm
hcgaloi View the latest post
There are no new unread posts for this topic. Scott CR1 frame size?
sanfairyanne
Mon Nov 20, 2017 11:20 am
jekyll man View the latest post
There are no new unread posts for this topic. Buying a C60-what frame size?
Noctiluxx
16
885
Sat Nov 04, 2017 6:59 pm
audiojan View the latest post
There are no new unread posts for this topic. Colnago World Cup frame size [help]
biker11122
16
1128
Sat Aug 05, 2017 7:17 pm
biker11122 View the latest post
Users browsing this forum: Bing [Bot], bumpkin, Catagory6, ChristianB, Delorre, Google Adsense [Bot], jpshorts, prebsy, RussellS, userfriendly and 48 guests
