It is currently Wed Jan 17, 2018 4:25 pm
Post new topic  Reply to topic  [ 539 posts ]  Go to page Previous 114 15 16 17 1836 Next
PostPosted: Sun Aug 10, 2014 4:03 pm
Hey all,
I'm thinking about the Hongfu FM066sl frameset as my next frame, and I just want to make sure I pick the right size. I'm 5'8" for reference.
I've made this handy chart that compares the geo of my current frame to the next closest 3 frame sizes of the FM066sl
This shows that the frame with the same TT measurement is a 50cm. But the frame with the closest HT and ST angle is the 52cm. What I'm confused about is that I've seen posts by people who are around my same height and ride the 54cm. This is maybe due to just longer inseam and arm reach? Seems very weird to me.
So my question is, which should I choose, 50cm or 52cm in the FM066sl? The smaller frame would maybe need a slightly longer stem than I have now, but the larger one might need a shorter one?
Thanks!
PostPosted: Mon Aug 11, 2014 7:52 pm
Resident master of GIF
52 bruh , angles are the same and you can slam the stem. I'm about your height and would probably holler at the 50cm, but if you like the way your current nashbro rides then get the 52. do not even consider the 54.
Nate ★ Life , my tumblr joint
Instagramz
My Podcasts
PostPosted: Mon Aug 11, 2014 7:56 pm
+1, though the tall head tube will create problems. If you already have the stem slammed you don't have much to do. Even with a negative rise stem you'd get around 1 cm of extra drop.
The longer TT (or more correctly, the shorter stem to get the same reach) would lead to different handling. Or you could try getting used to 1 cm more reach.
SHUT UP LEGS
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
PostPosted: Mon Aug 11, 2014 10:48 pm
What would the disadvantage to be to going with the 50cm? The ST angle could just be negated by scooting my saddle forward, right? But would the .5 degree difference in the HT be very noticeable? I'm just concerned about the reach on the 52cm.
PostPosted: Mon Aug 11, 2014 11:21 pm
You'd need to scoot the saddle backward.
Well, different HTA means different handling. Nothing outrageous, it would certainly be manageable but, different.
The 52 cm would also have different, twitchier handling as you'd use a shorter stem.
Btw both of these have a taller HT than the nashbar, that could be a problem.
SHUT UP LEGS
PostPosted: Mon Aug 11, 2014 11:51 pm
Thanks for the info. I don't think the taller HT will be a problem as I've got my Nashbar setup with a positive rise in the stem, and it's got about 1.5cm of spacers underneath. That means I should be able to go more parallel with the stem on the FM066sl and also use less spacers.
PostPosted: Wed Aug 13, 2014 6:04 am
I'm about 167cm and my lbs said I should get the 50cm Bianchi frameset, I ride a 52cm trek madone at the moment. I think a 50cm could be too small maybe? It will be ordered in so I need to get it right. You could just move the seatpost and stem up? Other option is a trek madone 5 series frameset that has front stupid carbon dropouts and steel on the back.
-Trek Madone 6 Series SSL 2012 with Sram Red 22 and American Classic Aero 420 wheels
-Bombrack Divide 2013
Also
Metho Everything!
PostPosted: Wed Aug 13, 2014 8:39 pm
50 looks right unless you have very long legs and arms for your size.
Look at J.Rodriguez's bike : http://www.cyclingnews.com/features/pro ... -aeroad-cf
PostPosted: Thu Aug 14, 2014 3:34 am
Yeah I think it will be right. Bianchi have weird sizing options. Don't Panic :|
Also
Metho Everything!
PostPosted: Fri Aug 22, 2014 5:59 pm
I''m about 1.83 with a inseam of of 86.7. I'm planning of buying a Giant TCR advanced, the store advised me a medium frame size after they measured different bodyparts. He said the top tube is more important than the frame size. There was even no doubt between te m and m/l, the m/l was to large for a perfect position.
But when i look at the giant site that looks very small. The medium is for persons between 1.70 and 1.78. What do you people think about this?
Sorry for my bad english i'm dutch. The geometry of the giant trc is as follow:
PostPosted: Wed Sep 03, 2014 6:33 pm
I was wondering if I could get some help with geometry between two bikes.
I'm currently riding a Cannondale Supersix size 52 with approx 35mm of spacers off the head tube and 110mm 0deg stem
Geometry:
I'm looking at picking up a used Seven Mudhoney cross bike. This will have a 395mm A-C fork and the following dimensions:
ST(cc): 47 cm
TT(eff): 54.8 cm
HTA: 72.5 cm
STA: 73.5 cm
BB: 7.5 cm
HT:11.2 cm
FrontCenter: 58.5 cm
Can I make this bike work?
PostPosted: Wed Sep 03, 2014 6:40 pm
Do you have stack and reach for the frame? It's got the TT length of 54 SuperSix but a shorter head tube. If everything stayed constant, you'd have to go to 100mm stem and add another 10cm below it. By 0-degree do you mean no-rise (-17)? If that's the case you try a -6 degree stem or something. It might spare you the need for a shorter stem or additional spacers.
PostPosted: Wed Sep 03, 2014 7:39 pm
Since the mudhoney is a cross bike and the fork is 28mm longer A-C(395 vs 367), shouldn't the stack be taller? With a taller stack, the reach would be shorter when compared to a road bike of similar top tube length?
Does anyone have a spreadsheet or calculator they could put this into?
PostPosted: Mon Sep 15, 2014 2:44 am
NEED some help,
I normally ride a 55cm top tube road bike and am looking to get a canyon TT bike, however, after inputting all the data, I seem to be inbetween a Small and Medium? does anyone have any experience with this bike to help me out here? thanks
my measurements are:
height: 181cm
inseam: 84cm
torso: 52cm
shoulder width: 46cm
arm length: 57cm
I had a 54cm cervelo p2C before and ride a 54.5-55cm top tube Colnago
The Harem
Speedvagen | Argonaut 2.0 | Cherubim (S) | Mosaic RT-1 | Festka Scalatore | Pegoretti Responsorium Ciavete | Wilier Cento10Air Ramato | Trek Madone 9
Incoming
English | Field
Ex's:
Factor | Field | Baum | Stinner | F10
Edited topic title. writing in capital letters is like screaming on the internet. I also made the title describe the question.
 Post subject: Re: CANYON SPEEDMAX CF
PostPosted: Mon Sep 15, 2014 3:47 am
Sorry my torso is 68cm
The Harem
Incoming
English | Field
Ex's:
There are no new unread posts for this topic. C60 Disc Hexlock - bike fitting?
Disc0
Mon Nov 13, 2017 3:13 pm
Disc0 View the latest post
There are no new unread posts for this topic. bike build questions...
izz012
26
1866
Wed Oct 04, 2017 11:21 pm
hcgaloi View the latest post
There are no new unread posts for this topic. Buying a C60-what frame size?
Noctiluxx
16
850
Sat Nov 04, 2017 6:59 pm
audiojan View the latest post
There are no new unread posts for this topic. Scott CR1 frame size?
sanfairyanne
Mon Nov 20, 2017 11:20 am
jekyll man View the latest post
There are no new unread posts for this topic. Frame size comparison Evo Vs Synapse
ukracer
Sat Oct 07, 2017 8:38 pm
ukracer View the latest post
Users browsing this forum: Bing [Bot], Fiery, Global, KarlC, wingguy, Yahoo [Bot], zoki76 and 36 guests
cron
